2012 GS Coupe LS3 Gas Mileage
3rd Gear
I have 52,000 miles on my car, clean and replaced factory air filter everything is stock in the car, using 93 octane gas. Gas mileage on the highway at highway speeds plus 10 seems to stay around 22.5 - 22.9 running Michelin RF @ 34-35 PSI hot.
This is a 6 speed manual car; seems I should be getting better mileage??
seasonedgrandsport (05-21-2018)
3rd Gear
GS Mileage
Not sure what speeds you're traveling at as 10 over is not very indicative of actual speed not knowing the speed limit. All that aside my GS doesn't get great gas mileage either, but does seem better than yours. I think the wider tires add to the rolling resistance and are somewhat to blame. At 65 MPH the best I can do is 26-27 MPG. By the way I'm running Michelin PSS ZP and my car is a 6-speed manual as well.
You're heavier than just about any other C6. In 6th gear, you're turning your engine faster than a base model (different O/D ratio). And the bigger/heavier tires don't help any compared to a base model.
My previous Vette was a 2013 GS M6. It would get low to mid 20's mpg on the highway. Current 2013 M6 narrow body gets mid to upper 20's doing the same work.
Nothing "wrong" with your Vette. Worry about something else. It kinda is what it is.
astaggs (05-21-2018)
A lot of that must be in the wind resistance cause I have a Z51 NB, but with wide tires F&R (275 & 345s), with 4.11 gears, and it'll get upper 20s pretty easily on a highway trip. It'll get 22-23 when on E-85 as it's set up flexfuel.
3rd Gear
GS Gas Mileage
