Column lock?
Fortunately, if your ‘05 C6 is anything like mine, you are getting this message when you are trying to start your car? In this case, turn off your ignition, put the tranny back in reverse (just like when you shut everything down), then put it back to neutral and try to start it again. That seems to recycle everything
I’m sure you will get more ‘profesdional’ responses, but this has been my experience.
https://www.ebay.com/p/2005-C6-Corve...tor/1862746687
Quick run down on how to get to the SCLM.
Now before you watch the video, understand that before you disconnect the steering column lock connector from the SCLM, the steering lock has to be in the unlocked position. So if you can't get the steering column to unlock for you (get the message instead when you put the car into run mode, motor off, by holding in the bottom of the starter button for 5 seconds), the disconnect the batter for a few mins, reconnect it, then put the car into run mode, motor off again.
Also since the video does not show these steps, once you unplug the Steering column lock connector from the SCLM, unconnected the other connector, pull the SCLM out of the car, use spray electrical contact cleaner to clean the socket pins, and both connector pins that you will be reconnecting to the SCLM (main and the eliminator connectors), before you clip the SCLM back in the car, and connector both connectors back to it.
You want the red can CRC spray electrical contact cleaner , not the blue can of crc spray cleaner.
Once you have installed the eliminator, next go through your charging system to make sure that all the connection points have been cleaned and dielectric greased as well.
To add with the age of your car and humidity of your area, would be a good time to go through a few more connectors to clean and dielectric grease them as well when you have the battery disconnected.
https://www.corvetteforum.com/forums...intenance.html
If at some point down the line, you get a DIC voltage drop below 14.1V, but the main charging system is fine as pointed out in the above link, then you know that you have a problem from the Engine fuse block and down line isntead.
Hence the above like is a good primer, but does not hurt to pull the upper engine fuse block to give its lower pins and lower blocks a good cleaning, dielectric greasing, as well the BCM, ECM and even EBCM connectors since these the main connectors inside the car.
Then as you are working in an area of the car doing something else, any connectors you run across, clean and electrical grease them too. Hence if you are pulling a rear light to say change a bulb, you have the rear light main connector inside the bumper cover that loves to corrode over time as well.
So by staying in front of any corrosion pin problems before they happen, you stop electrical gremlin problems from popping up later instead.
Note, there is the option of taking a few hours to pull the steering colum lock assembly out of the steering colum; to pull it apart, cleanup and re-grease is gears to solve the problem, but take hours to do such, as well an item that you would need to do every few years over again as well. If you feel that you want to do this to keep the steering column lock in play, isntead of installing a column lock eliminator instead, then let me know and I can walk you down the rabbit hole plunge for that. Myself, have a perfectly good working steering column lock in 2005, but still have installed the eliminator, since it not a problem of if, but when the steering column lock starts to have problems with worm gearing binding up instead.
Also, since due to the humidity in your area, the electrical pin connectors can become corrode, which can cause not only the lock problem to begin with, but other electrical gremlins in the car as well.
I have seen SCLM get a little funky when the it main connector pins are slightly corrode, and the module not seeing full voltage from the same problem up line of the SCLM connector as well.
No, because in the unlocked position, the SCLM is looking for a 294ohm resistance on the sensor wires, and in the locked position, 487ohm instead.
This is the reason for the eliminator having a latching relay, with the two resistors needed to send back the correct resistance on the sensing circuit wires when the relay is latched the the two different directions instead.
Hence SCLCM fires the eliminator latching relay to the N.O position when you go to start the car, and the resistance back on the sensing circuit wires is 284ohms. When you shut the car off, the SCLM fires the latching relay to the N.C circuit side, and the sensor wires have the 487ohm reading to keep the car happy isntead.
On on another note since the dash is apart how do the light bulbs for the hud and options buttons get replaced? I have the switch pods apart and the tiny bulbs are soldered to the board. Replace the whole board? Dealer?
https://www.corvetteforum.com/forums...light-out.html
I haven't done the charging system PM as outlined above yet. Hopefully that will fix it.
I figured my last option was to drop 150 for a new column lock module so before doing that I yanked the dash apart again and removed the CLM for a closer inspection. I still didn't see any cold solder joints but just to be through I reflowed the solder on all of the major pins underneath the relays and connector pins. I also managed to remove (i.e. break) the cover on one of the three relays. Those contacts looked good and the movement of the contact arm seemed ok so I left it alone. Fearing that attempting to remove the remaining covers would damage the board I elected to try it out once more and amazingly it fired right up first try and no SCS message. Previous to this session I had removed the CLM and cleaned and greased the connections but that didn't help.
So the bypass is in all is good. And on the plus side, I had the opportunity to replace the mini light bulbs in the option buttons around the instrument cluster.
