Spark Plug Wires
Old May 28, 2018 | 03:56 PM
RobJoy's Avatar
RobJoy
Default Spark Plug Wires
1. How long should the spark plug wires be good for on the C-6 LS-3?
2. What should they be replaced with? My car is street use only. Is the GM OEM satisfactory for this application or is there something better that will improve performance noticeably? I have a BTR Stage 2 cam and new iridium spark plugs.
3. Is there any kind of concern for radio interference like the old Vettes?
Old May 28, 2018 | 04:02 PM
xBoostx's Avatar
xBoostx
If you are not getting cylinder misfire warnings they can last for 100k miles unless burned by headers.
Old May 28, 2018 | 04:16 PM
RobJoy's Avatar
RobJoy
So, would the misfire warnings show up on the DIC?
Old May 28, 2018 | 05:01 PM
HOXXOH's Avatar
HOXXOH
Not thinking about changing wires yet at 153K miles. No misfires either.
Old May 28, 2018 | 05:14 PM
RobJoy's Avatar
RobJoy
Don't you just love these LS-3's...
Old May 28, 2018 | 10:20 PM
torquetube's Avatar
torquetube
No. You can also have pretty considerable misfiring without the CEL coming on.
Heat will kill the wires. They can get brittle enough to come apart with a moderate pull. If your wires survived installation of your new plugs, they're probably not overcooked yet.
Old May 28, 2018 | 11:34 PM
Cherokee Nation's Avatar
Cherokee Nation
MSD 8.5 wires are what you need....I'm sure headers are next...Right?
Old May 29, 2018 | 11:56 AM
Mike's LS3's Avatar
Mike's LS3
… and with headers this can occur at a quicker rate, unless the wires are protected with wire boots.
Old May 29, 2018 | 12:05 PM
irok's Avatar
irok
new factory wires are as good as anything out there and all that you need
Old May 29, 2018 | 06:51 PM
2k Cobra's Avatar
2k Cobra
I will do wires when I change the plugs ~ 100K miles. Use OEM stuff.
Stock GS, no mods..
Old May 30, 2018 | 11:21 AM
timd38's Avatar
timd38
Stock GS, no mods..
I would do the same, in fact, that is what I just did on my truck.
Old Jun 3, 2018 | 05:52 PM
Dano523's Avatar
Dano523
Big think to remember, and that the OEM spark plug wires and even spark plugs have a resistance to them, than works as a RF noise suppression.
Without such, RF noise from the coils can make it way back to the ECM, which controls the alternator, and if the RF noise is bad enough at the ECM, then the ECM does not control the alternator voltage correctly, ending up with charging problems instead.
Hence OEM alternator should be putting out 14.7 volts, and with some after market plugs and wires, have seen the voltage drop below the 14volt level from the alternator isntead.
To Spark Plug Wires
