fuel pump failed start up test
Old Jun 19, 2018 | 04:38 PM
airmailmiller2009's Avatar
airmailmiller2009
5th Gear
Default fuel pump failed start up test
anybody replaced fuel pumps on 2009 convertible, major ordeal? drop tank plus trans to do this?, what is cause of this failure most of the time.. thanks for any info.
Old Jun 19, 2018 | 05:18 PM
torquetube's Avatar
torquetube
All you could ever want to know: https://www.corvetteforum.com/forums...fuel-pump.html
Old Jun 20, 2018 | 03:42 PM
Dano523's Avatar
Dano523
Best advice I can give you, get an anolog gauge on the pressure rail, jump the relay by hand, and see if its the pump or relay the problem to begin with.
Hell, most of the time it just the relay, or fuse box at the relay that is the problem instead.
Old Jun 21, 2018 | 06:29 PM
airmailmiller2009
5th Gear
thanks I 'll look into it and see what we have.
To fuel pump failed start up test
