HELP! Many electrical gremlins!
Old Jun 24, 2018 | 03:39 PM
ShaWING66's Avatar
ShaWING66
Default HELP! Many electrical gremlins!
Where to begin... 2011 manual grand sport. basic package... no Bose or telescoping steering wheel or anything.
So about a week ago after I had the oil and alternator belt changed, I started getting the infamous "get service soon, service ABS" warning. It happens every time I drive, after the car warms up for a bit. The weird part was that this time, unlike what happened on my previous C6s... it would clear. And then come back, about every 30 seconds. The red "brake" light would be illuminated as well as the ABS light. And then clear and come back. I did not do a brake check to see if my ABS were actually disabled. I believe the traction control service warning would also come on occasion. The other weird part is my turn signals stop "chiming" but will still work. Same with the hazard switch. Nothing comes on in the dash and doesn't make the clicking noise, but the actual lights work... left right and hazard. The gas and water temp gauges also go to zero... and then come back. The car seems to be running fine otherwise. I am running to advance auto now to read any codes. I will update the post when I get back.
Anyone have anything like this?!?! The previous owner treated this car like crap and im pretty sure supercharged it as I discovered over the past year and a half of owning it.
Old Jun 24, 2018 | 08:02 PM
ShaWING66's Avatar
ShaWING66
So, for some reason I couldn't get a reading from the OBDII port... kept getting an error. Add it to the list. I am also getting a "service fuel system" error. WTF??
Old Jun 24, 2018 | 08:38 PM
BadAV's Avatar
BadAV
First thing to do is have the battery load tested. Weak batteries cause all kinds of wacky issues in these cars. Beyond that, I don't have any other suggestions. Good luck.
Old Jun 25, 2018 | 12:47 AM
Cherokee Nation's Avatar
Cherokee Nation
The cheap code readers at parts stores will not read the codes you have....You need a Tech11 to read them.
Old Jun 25, 2018 | 09:31 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
I would start with the battery, test it with a multi meter with car off and test alternator power output car running.
I would take apart the fuse block under the hood. It separates into 3 sections. The first section where all of the power wires go can sometimes have tension and pull away from the pins.
I had an issue where the bolt pin on that area was not tight enough and caused a weak power connection.
I would then test and remove all the connections at the passenger floor board area that are known to become loose.
Old Jun 26, 2018 | 12:29 AM
Cherokee Nation
Do NOT do what is in post # 5!!!!
Old Jun 26, 2018 | 12:47 AM
JerriVette's Avatar
JerriVette
I have 122k miles on put on my 2008 and I’ve found the first thing I do when I have intermittent electrical issues is check the age of the battery. I’ve had battery’s tested and they test fine...yet I still had electrical gremlins.
i changed the battery with a new one and all my electrical gremlins disappeared ..
ive found that the c6system is extremely sensitive to having a good battery.
Ive also found that between 27 and 36 months my electrical gremlins pop back up even with a 42month Oem delco battery..
before chasing electrical gremlins..change out a 150dollar battery..
thats my two cents..
works for me and like like I said the gremlins disappear..
best place to start...
sometimes the simpliest solution is the best.
hope this helps and just my two cents with 122k miles of experience.
Old Jun 27, 2018 | 06:40 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
LOL ok what exactly would you do and why should he NOT do what is common sense?
Old Jun 27, 2018 | 11:58 PM
Cherokee Nation
That is the last thing i would do.."Common sense"...Have you not heard all the horror stories after the dealer took the fuse box apart for the Recall fix for the low beam headlights.......I'm one of them.....I did not even make it off the dealers property before it crapped out.......Read post #4
Old Jun 28, 2018 | 07:36 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
NO i have not heard any horror stories regarding taking apart the fuse box. It is a simple check. The dealer is the problem with most fixes and perhaps did not do their jumper wire correctly.
Tech2 scanner is a bit of over kill to figure out if the battery is taking a charge or not. You can figure that out with the battery dead cell check and what your alternator is outputting.
If the BCM connections are loose that is an issue or if the fuse box panel has a power wire that has too much tension or failure in the connections due to heat soak are common failure points.
Old Jun 29, 2018 | 12:40 AM
Cherokee Nation
I don't mean that he needs a Tech 11 to check the battery volts.If he knows how to read a simple VOM he could check....Only a tech11 or a Snap On scanner will pull the codes for ABS,traction control and the other problems he is having...He did not say anything about his battery...............
Old Jul 2, 2018 | 01:53 PM
Red86Cfour's Avatar
Red86Cfour
I use an interstate battery, I think its MT86, that has a two year complete replacement warranty and change it out before the two years expire even if I am not having any problems.
To HELP! Many electrical gremlins!
