RSD Line Lock Install problems on ‘13 GS
I’ll start by saying that the RSD kit seems to be top quality and is a well thought out kit.
However, basically, after much research online, I have concluded that the kit I have was not designed to fit the ‘08-‘13 C6s, which have Bosch master cylinder with different sized (12mm x 1.0 inverted flare) ports, as compared to earlier models. The specific problem is that I could not use either of the two hoses or the adaptor that came with the kit, as they do not fit the master cylinder port or the hard line which runs from the M/C to the ABS module. I have not been able to ascertain if RSD makes a specific kit for the later model C6’s, but they certainly do not advertise it on their website, nor is there an option to order a ‘08-‘13 specific kit, like what Cartek does.
To add to my frustration, it seems that it is next to impossible to find a 12mm x 1.0 inverted flare adaptor fitting that can adapt to either 1/8” NPT or -3AN. I’ve found a bunch of aluminum 12mm x 1.0 to -4AN adaptors, which would require me to add a -4AN to -3AN adaptor, but there’s not a lot of space to add a bunch of adaptors and then still turn downwards towards the line lock inlet port.
Luckily, I had some Wilwood S/S brake hoses on hand that had a 12mm x 1.0 invented flare fitting on one end and -3AN female fittings on the other end. They are a bit longer than needed and I would’ve liked to get them the right length, but I was glad I had them, otherwise I would’ve had to scrap the RSD kit entirely. So, in the end, I bought a short piece of hard brake line, a double flare tool and some 12mm x 1.0 flare hard line fittings and made up a very short (like 2.5”) 12mm male to male hard line and bent it to fit into the 12mm end on one of the hoses and run that to the inlet port of the L/L.
On reflection, it would have been way cheaper to just figure out what was needed and buy a regular line lock and the necessary hoses/lines and adaptors myself. Or the correct Cartek kit, which is what I wanted but they don’t offer shipping overseas on their online store. Neither does RSD, so I bought their kit from another vendor.
Below are a bunch of pictures which, hopefully, speak for themselves:
This is the RSD hose end that is supposed to screw onto the factory hard line. Neither the thread or the style of fitting works
12mm x 1.0 port in Master Cylinder
Final install, with too-long S/S hoses
On the right is the M/C to S/S hose adaptor fitting that comes with the kit, compared to the 12mm x 1.0 fitting that screws in to the M/C.
The entire kit as delivered. Neither of these hoses will work on ‘08 up C6 without adaptors
everything bolted right up on my 05 car and friend installed one on his 09 car last year.he never mentioned having any issues with his install.when I get a chance to look at his again I will see what the differences are.its a bitch when you don't have the proper parts and makes simple jobs more complicated than need be.
Not knocking your kit or install at all. But couldn't help myself when you talked yourself right to it at the end of you 1st post.
Just another way to do it.
Wait, where’s your windshield washer reservoir? You have way more space there than I did!
Good catch on the wiper bottle. It has since gone away for other things to occupy that space.
I have a pic of it installed with the bottle some where. Just the way you bend the tube. Also notice the bracket on the noid fit perfect to the mount of the MC stud and hangs under the MC. Good luck with it!
I have a pic of it installed with the bottle some where. Just the way you bend the tube. Also notice the bracket on the noid fit perfect to the mount of the MC stud and hangs under the MC.Good luck with it!
I also like that your solenoid is much farther away from the header in that location too.If I had to do it over, I would do it just like that. In fact, I may very well buy a few more adaptors and bend myself a hard line from the M/C to the solenoid as well. Looks way neater than mine.That frickin washer bottle neck damn near drove me nuts the other night. It’s a bitch to get your hands anywhere in the engine room of one of these C6s.
I’ll try it the next time with my left foot resting lightly on the brake pedal and see if that cures the problem.
Hell better way yet, is to go into the controller of the EBCM , and pick up the valve exit solenoids to lock the brakes up that way isntead.
With some diodes, the EBCM will never see the power being applied to just solenoids to hold the exit valves closed, nor the pressure being held in the ABS unit itself with you off the brake brake pedal, so will not freak out the EBCM unit to start throwing codes.
If you hit the button again it will enter "Comp" mode and keep TC off and turn AH (active handling) off. You don't want this mode on when you make the hit AH is your friend. My GS's a 12, I run a 28" Hoosier (15" rim) and 26" M&H skinny (17" rim) no issues burnout or hit and the "noid" I have is the same as the one in included in the RSD kit .
Give my post above a try. You should be happy!
