Charge Service system when car started
I noticed a couple days ago when I start my car it tells me service charging system for roughly 10 seconds. It sits around 12V, and then goes to 14ish and fine the rest of the day. Is this something I should be concerned with?
As for solves, start here,
https://www.corvetteforum.com/forums...nator-fix.html
Then here next,
https://www.corvetteforum.com/forums...intenance.html
I do have a question and narrowed down a little. When I am running my ac after my car warms up and I drive it for a while if I am sitting at a stop light the Voltage drops to around 10/12. When I start driving it goes back up to normal.
If the voltage to the modules drops below 12 volts, its going to cause the modules to program glitch. So about the lowest. that you want the dash or DIC to tell you voltage, is 12.5 or higher isntead. If you are getting reading of lower than 12.5 volts with everything on, including the lights and raditor fan, then need to find the problem as pointed out in the post I listed under voltage check points.
