2006 c6
Old Jul 2, 2018 | 03:30 PM
Jeffrey Odom's Avatar
Jeffrey Odom
1st Gear
Default 2006 c6
I recently bought a Corvette my seats have stopped working two days after I got the car the seats will work on the wrap around it lumbar whatever it's called it all works but the up and down or the back or forwards or backwards and the passenger side won't work at all has anyone else had this issue
Old Jul 2, 2018 | 03:47 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Welcome to the forum, Jeffrey, and congratulations on your C6!
Bummer you're having problems with it.
I'd recommend posting your question on the C6 section of the forum at https://www.corvetteforum.com/forums...2005-2013-14/; probably post in the Tech section.
Best wishes with an easy fix.
Old Jul 2, 2018 | 05:44 PM
Moved to C6 Tech.
Old Jul 3, 2018 | 01:14 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
First & easiest is to check the connectors under the driver's seat. Sometimes they get kicked loosed when the seat is moved back & forth.
To 2006 c6
