Need help id'ing lifter
Old Jul 23, 2018 | 01:30 PM
mika401's Avatar
mika401
Default Need help id'ing lifter
bought vehicle with motor built by Advanced Induction and they have have been completely useless in helping me with background info.
Had a lifter go bad and wipe out the cam so need new cam & lifters but have no idea what lifters are existing. can someone help ID what these are?
Old Jul 23, 2018 | 02:02 PM
Tech's Avatar
Tech
I can't help you identify them but it shouldn't really matter which set was in there. I would replace all 16. They aren't all that expensive but the labor to swap them out later is.
Old Jul 23, 2018 | 02:05 PM
mika401's Avatar
mika401
More looking to know if they're standard or low lift or custom something
Old Jul 23, 2018 | 03:51 PM
Tech's Avatar
Tech
Whomever is doing your engine work (or whomever is selling you lifters) can recommend a set based upon the rest of the valvetrain components and intended use. That's the route I'd go 100% of the time.
Old Jul 23, 2018 | 08:33 PM
Unreal's Avatar
Unreal
Never hard of AI building a car, they just port and rebuild heads, so wouldn't expect them to know anything besides what heads are on it, unless they actually did put this together, which I've never heard of.
Like Tech said, figure out what cam/springs/etc etc you are using then select a new set of 16 lifters based on your setup, not what you had in there.
Old Jul 24, 2018 | 02:28 PM
bmfvette's Avatar
bmfvette
Maybe he means an employee of AI. Never heard of them do anything outside of heads since Tooley was there.
Old Jul 24, 2018 | 02:40 PM
mika401's Avatar
mika401
Was able to find an old Cam box from Bullet Cams, they ran the serial # and confirmed it was sold to AI with whom they no longer do business with....Anyways, new cam is on order, I am the one putting it back together, my goal was for direct replacement so as to maintain the valvetrain geometry and re-use as much as possible. As of yesterday in talking to Texas Speed and measuring the existing lifters are short travel and most likely Comp. So now need to figure out do I stay with short travel or go back to standard travel with likely longer push rods.
Old Jul 24, 2018 | 02:51 PM
Tech's Avatar
Tech
Pick a lifter. Measure for pushrods. Buy pushrods if yours aren't the correct length. Don't be pennywise and pound foolish. Pushrods are about $100.
To Need help id'ing lifter
