#3 If the total promo code usage reaches 25 units, we will do a random drawing and the winner will receive a full credit and your purchase will be totally FREE.
Still checking out rates, everything so far is coming back in the $300-400 range. A new company is coming in Wednesday to talk about international shipping. Let's see what they say
I will be in by tomorrow night, got to talk to my mechanic and financier...(wife) lol. 2008 z06 with a texas speed stage 2 cam on a fresh motor 550 rwh, overheating a bit on the 102 degree days. Need to check for the external oil cooler??
Tom, is this an extra core type radiator as compared to our OEM stock radiators on the LS7 models? It would seem I need this model,1139105A- This model includes one 7-plate internal oil (TOC) cooler on the passenger side. GM quick connect fittings included. Applications are:
All Z06 (Except 2012 w Z07)
All C6 with Automatic transmission
All dry sump engines
Cooling fan option, how much better?
I am looking hard at that combo kit option!!
Thanks in advance for having a built in the USA company!!!
I know there's quite a few options for radiators on these cars so just double checking before I place an order. I've got a 2010 GS manual trans and I should need part number 1139105A ? This is the stock replacement? Thanks so much and looking forward to having it!
I think so, not positive if the GS changes that but it all comes down to how many coolers are inside. None, TOC,or EOC, or both. 0 or 1 or 2. Easy to check
I'll try to check tomorrow, all I really know is it does have the dry sump. Would there be any advantage/disadvantage in switching from the separate air to engine oil cooler to running the engine oil through the radiator? From what I'm reading about the M6 GS, the stock setup seems to work well on the track (haven't tracked mine yet) but some are complaining that it takes too long for the oil temps to come up to normal. I've also noticed that it does take quite a while even in the summer.
