traction control
Hence Tech II will clear the stored DTC codes in memory, but if the problem remains, it going to keep throwing the code each new start up again.
Hence if you solved the problem, then although the DTC code is stored as being thrown at some point from a previous start up that you can find using the Tech II in the DTC list, you should not be getting any trouble lights or DIC problems listed for that start up if the code problem has been resolved. So if you still have DTC problems still showing up in the dash lights /DIC, the problem has not been solved, since the code was thrown again that start up as well.
thank you for the fast response, I do not know the code, I will get a code reader.
normally my mechanic will reset codes, the right rear hub has been replaced 3x the last in April 2018. Car now has 111,000 miles, this is July 28, 2018. Purchased vehicle used with 30,000 miles. Have read about electrical connections and will do some checking. When I figure out the code I will respond, again thank you for your help.
Bill
