Air intake question
Old Jul 31, 2018 | 02:13 PM
C6ness's Avatar
C6ness
Default Air intake question
I have a K&N CAI on my 09 vette and was wondering if anyone had removed (put holes in?) any of the plastic valley that the intakes filter fits into. I'm thinking maybe that would get cooler air to the filter as I can't really see how ,as it sits, the filter is drawing any significantly cooler air from under the hood. Is this wise or would doing so cause a problem? I don't want to go to another CAI set up, just trying to get cooler air to what I already have. Appreciate any suggestions.
Old Jul 31, 2018 | 03:54 PM
damascus1986's Avatar
damascus1986
are you talking about the shroud below the intake? many have done the propped shroud mod with some toggle bolts for 5$. when i had a stock intake with kn drop in it helped lower temps. i switched to the halltech and could no longer keep the shroud propped because it caused a lot of surging on the freeway
Old Jul 31, 2018 | 04:11 PM
C6ness's Avatar
C6ness
Yes the shroud. What is the propped shroud mod? Sounds like what I'm thinking about.
Edit. Found a thread talking about the propped shroud. Possible surging. Guess I'll just leave things alone. As of now air intake must pull air from behind. Up over the radiator between the intake and the hood I guess. Hmmm. Maybe just put some holes in the shroud on each side of the filter?
Old Jul 31, 2018 | 04:26 PM
damascus1986
heres the link
https://www.corvetteforum.com/forums...gle-bolts.html
looking at it looks like the guy that made this thread had the kn intake so it may work well with it. my halltech moves the MAF so that maybe the cause of my surging with propped shroud and intake
Old Jul 31, 2018 | 04:36 PM
C6ness's Avatar
C6ness
heres the link
Old Jul 31, 2018 | 05:04 PM
damascus1986
anytime man hope it helps before i had the intake i used a tablet with a app that could read intake temps propped shroud sure did help
Old Jul 31, 2018 | 05:33 PM
C6ness's Avatar
C6ness
Very interesting. Looking for all the help I can get down here in the florida inferno.
Old Oct 4, 2018 | 10:02 PM
C6Tally's Avatar
C6Tally
I'm thinking about trying this propped shroud mod as I just got a K&N drop in filter.
Has anyone had any trouble with the toggle bolts getting dislodged and falling out while driving?
Is there any alternative anyone has tried with drilling or cutting the shroud itself?
Old Oct 5, 2018 | 03:27 PM
damascus1986
for me i had no trouble with this the two butterflies helped plenty. up to high speeds.
i personally would shy away from cutting the shroud i have thought about drilling small holes ( on the sides) to allow some outside air in but i would be cautious because of how touchy the MAF can be
Old Oct 5, 2018 | 03:32 PM
damascus1986
some have installed this but it might be a bit more money compared to 5$ toggle bolt install
http://www.theair-charger.com/howtoinve.html
Old Oct 9, 2018 | 10:41 AM
C6Tally's Avatar
C6Tally
Interesting, like a scoop, only upside down.
Old Oct 11, 2018 | 05:58 PM
damascus1986
not sure if theres much of a difference compared to propped shroud might be better for those with with surging issues
To Air intake question
