Looking for a rocker switch but not sure what it would be called and getting lots of hits on Google but not what I want. I want a switch with one position off, toggle on, then momentary if I push further. I want to wire my meth pump to the rocker for on/off and then trigger the solenoid with the momentary to test flow.
if I get desperate I can use a switch and a pure momentary but would like a single switch. Anyone know where to find or what it would be called?
http://www.elecdirect.com/cole-herse...QaAqybEALw_wcB
Try this source. I'm a retired mechanic and have done quite a bit of electrical work and built a few prototype machines for various industries. The Cole Hersee company has been a good source for some specialty switches.
Thanks all. The one from Amazon is the same as I kept running into, both on positions are momentary and returns to off when released. But I didn't think of just searching for ignition or starter switch, that should narrow things down.
