I took a drive yesterday and when I parked cooling fan was still running after about 10 minutes. I checked once and temp was 217, after a little while maybe 20 minutes checked again temp was at 195. no reason fan should still be running with everything shut off, but the only way I could get it to stop was pull fuse. Put fuse in to drive home and when I got in garage fan keep running till I pulled fuse again. What could cause this?
