anyone replace visor ?
Old Aug 21, 2018 | 08:25 PM
Trebor's Avatar
Trebor
Default anyone replace visor ?
I have a small issue : The passenger side visor plastic flip up lid that exposes the mirror has a broken hinge so it hangs down on my 2006 Vert, I can't glue it because the plastic lid would be frozen. There must be a small light wire behind it that lights up the vanity lights. Has anyone run into this and fixed it? Where can I get a replacement visor? Hard to replace?
Thanks,
Bob
Old Aug 21, 2018 | 10:32 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default Visor
You can purchase new lid on ebay, around $40.00. Not the easiest to replace. Go to the How To section of the forum and there are videos for this procedure. There is only 1 wire and it goes up through the stalk.
Old Aug 21, 2018 | 10:42 PM
Dcasole's Avatar
Dcasole
Thanks,
Bob
Bob , its a very common problem , I bought mine from Cultrag Performance https://www.cultragfactoryparts.com/
or EBAY
https://www.ebay.com/sch/i.html?_fro...kw=c6+sunvisor
they are kinda ex[pensive but maybe you can talk one of these eBay sellers into only selling the one side u need
the install is very easy once you figure it out , u put a flat blade screw driver in the plastic mount on the header and spin the visor and the screw driver as a whole unit towards the door glass making sure the mount spun with the visor, then pull down and the wire for the light just unplugs . even if you break the old mount , the new visor comes with the mount , you plug the light back in , put the mount up in the hole in the header lined up with the window and spin it back towards the windshield
This link should help you [left]http://www.theredlion.us/DSV%20Sunvi...stallation.pdf
and this video should help you , but I am not sure why this guy pops off the mount ..
Dave
Old Aug 22, 2018 | 03:58 PM
719c6's Avatar
719c6
Just to throw it out to ya... I used a lid/cover from an 03 Alero. Exactly the same. Who would have thought?
Old Aug 24, 2018 | 12:01 PM
timd38's Avatar
timd38
Steering wheel is the same as an HHR..........
To anyone replace visor ?
