Engine cuts out at WOT
Old Aug 24, 2018 | 03:57 PM
Rdwarprbill's Avatar
Rdwarprbill
8th Gear
Default Engine cuts out at WOT
2008 roadster with LS3 motor. K & N filter and Diablo tune
Old Aug 24, 2018 | 04:39 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Hitting the rev limiter?
Old Aug 24, 2018 | 04:58 PM
Rdwarprbill
8th Gear
thanks fo your quick reply Ben. Yup, I think its hitting ng the rev limiter, but shouldn't my trans shift before that?
Old Aug 24, 2018 | 07:52 PM
ben dover's Avatar
ben dover
Does the tranny have a tune?
Old Aug 24, 2018 | 09:28 PM
toytruckman's Avatar
toytruckman
You will need to pull the trans shift point down so that it will start shifting before the engine gets up to the limit.
Old Aug 25, 2018 | 12:58 PM
Rdwarprbill
8th Gear
I uploaded theDiablo 93 octane program...don't know if it changed the trans shift points.
Old Aug 27, 2018 | 01:39 AM
Dano523's Avatar
Dano523
Will need to go in with something like HP tuner or EFI live to tune the trans (or have your can tuned customized) so your not bouncing off the rev limiter every shift.
Hence your flashing in a tune for a vet car, and with different gearing that that of a vet at final tire drive speeds, it has the trans confused when it trying to use it own sensors for speed shift points instead.
Old Aug 27, 2018 | 12:45 PM
mikeCsix's Avatar
mikeCsix
OP, two things, the '08 is a little slow at upshifting. When using the paddles, you might want to shift at 5k rpm's to give the transmission enough time to upshift. The programming was changed in '12 but can't be downloaded to earlier model years. There are some good transmission tuners on the forum that can help and since you are new with 4 posts, Dano is also a good source.
The other thing which you've already learned is to know everything about the tune you are loading into your car's computers.
Old Aug 28, 2018 | 07:02 PM
Rdwarprbill
8th Gear
Default WOT issues
[QUOTE=ben dover;1597858523]Does the tranny have a tune. I plan on calling Diablo re:trans tuning. Also, I have active handling option...since the rear end does get loose at WOT, could the active handling cause the motor to shut down?
Old Aug 28, 2018 | 09:26 PM
mikeCsix's Avatar
mikeCsix
As I understand it, yes it can. The computer is trying to use torque control when this happens.
there is a track I run at I seem to consistently trigger this reaction. Sounds like the a miss, but it picks up again pretty quickly. It's a tight left hand low speed turn with a short straight after it. I try to track-out as smoothly as I can, but hasn't made much difference.
Old Sep 2, 2018 | 08:36 AM
Rdwarprbill
8th Gear
Default WOT issues
will try using paddles to shift...also will hold back a bit at WOT and see if I can eliminate cut out. Thanks for your input.
Old Sep 5, 2018 | 09:43 PM
Boomer111's Avatar
Boomer111
And I thought autos where point and shoot.
To Engine cuts out at WOT
