Spark plugs
im looking for a spark plug recommendation
Let me start out by saying, yes! I’ve used the search button and found tons of posts on spark plugs. But that being said.... I haven’t found an answer
My car is 07 base supercharged, full exhaust, cam, , forged flat top pistons,meth injection, fuel system etc. should be knocking on the door of 700whp.
Fired it up on the base “drive ability” tune from my tuner and have been fighting my service charging system light ever sinc. Voltage at idle is all over the place. Don’t matter if it’s hot or cold from 11.8 to 14.3
battery is brand new, replaced the alternator checked the wires and terminals at the starter everything clean, tight, terminals are solid also.
I installed the Br7ef plugs. (Brand new and gapped then to .030) I’m thinking that this is my problem. After reading the other posts and even seeing GMs service bulletin about aftermarket plugs I want to try changing them...... But what do I change them to? In most of the other posts everyone says NGK-tr6 but people have issues with those as well
I would like to try the stock ls9 plugs 41-104 but I’m thinking that is going to be to hot of a plug for 700wheel
i would love to just tell the tuner to turn off the code but My voltage is low, interior lights will dim so I know I got to fix it.
does anyone have any suggestions or experience on what plugs I can use
As for checking alternator output voltage, use the rear terminal of it under the rubber boot as the positive source for the meter, and the body of the alternator as your negative source. The voltage out put of the alternator with the motor cold and A/C off so the radiator fan is not running, and driving lights off, should be 14.7 volts.
Now lets touch on after market parts on the car, and even if the voltage is 14.7 volts to start with, if you a dual fan set up , and even drawing more power for other items like HP fuel pumps, this could be putting a strain on the OEM alternator that it can not keep up instead. Also may be using an under drive HB, this is spinning the alternator slower at idle, and going to cause problems as well.
I ended up taking the alternator wire and standing it straight up. The service charging system warning is still on but the voltage fluctuation seemed to settle down quite a bit. I had it idling for about 40 minutes today with the headlights on blower on high and voltage was hanging out in the mid 13s it would bounce around a little but a lot better. When temp got around 200 and the fan really started working voltage dropped to the low 13s and would dip into the high 12s but then come back to low 13s
for now im going to leave it, until the tunner is done with it. From my understanding he should be able to adjust the idle charging characteristics. So we will see what happens. My appointment is set up for the end of the week I’ll keep you posted
I agree with Irok, put in fresh plugs before tune to prevent KR and issues during the tune.
Is that where the whole problem comes from? The NGKs with the copper cores or what ever,switching back to an iridium plug should take care of it? I’m understanding that the problem is with RFI but I just don’t enderstand how/why. Do I need just to put an iridium plug back in? Or just a protruded tip plug back in? Or do I need to get away from NGK plugs all together? I’ll buy what ever but I don’t wanna just be randomly buying sets of spark plugs and not have them fix my issue you know.
Im just bringing it to the tuner a day early and telling him to do what ever he wants, try and fix it, disable the damn code I really don’t care at this point lol
