6L80E stuck in 4th gear
Recently car was running great so we took it to the dyno. Drove fine, dyno fine but when I got off the dyno, the car stayed in 4th gear on my 6L80E trans. Even with paddle shifters it wont move. We put the tune back to stock and nothing. We tried the tune i previously had and still no luck. I got the car home, looked under and noticed some burnt wires over the exhaust but it was dark to see where they went. Following day I had to leave out of town. There are NO CEL codes. Can anyone tell me what wires these are... this is where they burnt.. its a red wire a beige wire and a black wire that come from trans harness towards the back driver tire area.. trans temps stay 150s-170s.. not sure if the wires are brake related or speed related or trans related. The car is only 450hp area and trans has about 20k miles.. ls2 fbo cammed and 3600 stall.. like I said.. it worked perfect before and during dyno..
car
car
Out of the Transmission from the Control Solenoid Valve Assy you have:
- Orange/Black > Park/Nuetral Signal to the ECM
- Red/White > ECM/TCM 15A Fuse in engine compartment block
- Black/White > Block ground
- Tan > ECM/BCM Data Bus Neg
- Tan/Black > ECM/BCM Data Bus Pos
Going by those colors (Red/Beige/Black) and it's the Transmission Harness:
Stuck in 4th gear
Did you get the problem fixed? If so please let me know because I’m having the same problem and no one can figure it out !!
car
Yea disconnected the battery same results...
