Harmonic balancer replacement advice - Ventura County
Old Sep 11, 2018 | 11:13 AM
mike82's Avatar
mike82
Cruising
Default Harmonic balancer replacement advice - Ventura County
My base model 2007 C6 has developed a wobble in the harmonic balancer at 160,000 miles. I use it as a daily driver, no racing it its past or probable future. Engine is currently all stock, although I will be installing a Billet alternator soon as I think mine is getting flaky.
Based on the advice presented in a number of threads, I'd like to replace the stock balancer with an ATI (either 917246 or 917266) and the ARP bolt. kit (234-2503)
The mechanic I have been going to for years locally will only replace with AC Delco or an aftermarket brand (in this case, Dorman) for the purposes of his 2 year/24000 mile warranty on his work.
His work has been impeccable over the years, so I'm hesitant to go to a different shop, but at the same time, I'd rather only do a job this big once, so I'd like to get a replacement part that is likely to outlive the car.
Does anyone have any recommendations for a mechanic in the Ventura County/San Fernando Valley who guarantees their work with non-GM parts?
Also, I'm considering replacing the timing chain and timing chain cover seal and given the age of the car. I don't see a lot of posts here about failed timing chains on the LS2, (excepting in UD pulley situations). Growing up, it use to be a common recommendation after 100,000+ miles to replace it. Is that still a thing or am I being over-cautious?
Old Sep 11, 2018 | 11:32 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
DDD...means “Don’t Do Dorman”...LOL !!
Old Sep 11, 2018 | 12:28 PM
Cockroach's Avatar
Cockroach
Mike82,
If your on a budget and are paying for repairs just go with what your guy wants to use. At 160,000 miles spending $ on performance parts makes little sense to me so a basic balancer is just fine.
To Harmonic balancer replacement advice - Ventura County
