Electrical question
Old Oct 8, 2018 | 12:25 AM
mcm95403's Avatar
mcm95403
Default Electrical question
Does anyone know if there "should" be a draw from the alternator when everything is off? I have something draining the battery, so I removed the negative terminal from the battery, put my voltmeter between those 2 points, and then started to unplug/disconnect things till the drain stopped. Even with all 4 connectors in the engine fuse box unplugged, there was still a drain. As soon as I disconnected the lead wire from the alternator (a 2 week old AC Delco reman unit) the drain stopped. Reconnected it and the drain started again.
Old Oct 9, 2018 | 08:20 PM
Dano523's Avatar
Dano523
Bad voltage regulator on the reman alternator.
Old Oct 10, 2018 | 05:47 PM
KB9GKC's Avatar
KB9GKC
I agree!
Douglas in Green Bay
To Electrical question
