interior moisture issue
Old Nov 27, 2018 | 11:43 AM
woodvette03's Avatar
woodvette03
Default interior moisture issue
i have a 2012 GS coupe. lately i have been getting excessive moisture inside. cargo area carpet was wet and in the drivers side compartment in the cargo area. i reached under carpet of cargo area and it was wet there. i dried it up with a towel as much as i could and have a few desiccant packs in there to help absorb some of it. my question is if anyone else has experienced this and know where it could be coming from. i readily do not see any seal damage around hatch area or doors. thanks a lot.
Old Nov 27, 2018 | 08:36 PM
Patsgarage's Avatar
Patsgarage
Have a friend hose down the roof/hatch area with a garden hose while you are inside the car, you should be able to pinpoint the area of the leak that way. If all the seals are OK, I would look for a clogged drain hole in the hatch area.
Old Jun 10, 2020 | 07:39 PM
daveb91's Avatar
daveb91
My c7 is finished in carpet.....
To interior moisture issue
