Brake Upgrade C6
Old Dec 9, 2018 | 09:38 AM
Jefffward's Avatar
Jefffward
3rd Gear
Default Brake Upgrade C6
I’m looking to upgrade rotors An calipers on C6 I have larger Z wheels and tires, any recommendations instead of buy a expensive Kit,? Any help would be appreciated
Old Dec 9, 2018 | 10:15 AM
PCMusicGuy's Avatar
PCMusicGuy
The Z06 wheels are wider, but they aren't any bigger in terms of diameter. Are you wanting to upgrade for looks or function? If it is for looks, there is not much that won't cost $1000+.
Old Dec 9, 2018 | 10:48 AM
myredhead1's Avatar
myredhead1
After going full wide body, I thought that my base brakes looked a little lost behind my wheels, although I didnt need the upgraded performance of the bigger calipers. I just searched the for sale section and found a great looking Z06 take off set for $1100 shipped which included all four calipers, rotors and SS brake lines.
Old Dec 9, 2018 | 11:10 AM
Jefffward's Avatar
Jefffward
3rd Gear
the new ones are larger diameter stock C6 were 18” front an 19” rear, these are 19” front an 20” rear, was hoping to find stock information for larger rotors and calipers to keep from having to buy 2k brake kit, like what C6 or C7 rotors An calipers that use 3 piston front an vented rotors an make a easy upgrade and less expensive
Old Dec 9, 2018 | 11:12 AM
Jefffward's Avatar
Jefffward
3rd Gear
thats Great I got wheels and tires did they tell you what the rotors An calipers came off of,?
Old Dec 9, 2018 | 08:51 PM
Shortpersonbk's Avatar
Shortpersonbk
Just find a set from a c6 z06 it will bolt right up and are cheap. They will how ever only look cool unless you track the car.
Old Dec 9, 2018 | 09:26 PM
myredhead1's Avatar
myredhead1
Yes, they came off of a 2009 Z06.
Old Dec 10, 2018 | 09:58 AM
PCMusicGuy's Avatar
PCMusicGuy
With that information, any takeoff set from a C6 GrandSport or Z06 will probably be your cheapest route. You are still looking at around $1000 to $1500 total depending on the condition of what is available.
To Brake Upgrade C6
