dash pod lights
Old Dec 13, 2018 | 02:16 PM
mike_hill's Avatar
mike_hill
6th Gear
Default dash pod lights
can the lights be replaced on the control area RH side of dash pod
Old Dec 13, 2018 | 03:35 PM
Sox-Fan's Avatar
Sox-Fan
Yes. They are soldered in. You can get the bulbs at amazon
https://www.amazon.com/gp/product/B00L8BR76A/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B00L8BR76A/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
Old Dec 13, 2018 | 06:01 PM
mike_hill's Avatar
mike_hill
6th Gear
Thanks much. Where can I go to get instructions to remove this board from dash pod?
Old Dec 13, 2018 | 08:11 PM
Sox-Fan's Avatar
Sox-Fan
No idea but if I remember right it works like this
using your thumbs on the inside face gently pull the gauge bezel back toward you. Pull the pod gently then unplug the wire for the circuit board. There is not a lot of wire, and it's a pain to get to the plug but with patience you can do it. I don't recall there being any screws anywhere at all. It all snaps together. That's the best I can remember. It was early 2016 when I did it. If you're gentle you can't really hurt anything.
Old Dec 13, 2018 | 10:25 PM
doomi's Avatar
doomi
I wonder if there is an option for led replacements.
Old Dec 14, 2018 | 11:37 AM
mike_hill's Avatar
mike_hill
6th Gear
Thanks for your input. Last thing I've ever been called is "gentle" but I'll give it a go.
Also like the led idea
To dash pod lights
