"C6 from 2005-2010 navigation radio clock stops after battery disconnect
Old 02-27-2019, 08:08 PM
  #521
rik8020
Cruising
rik8020's Avatar
I have an 08, replaced battery 13 mos. ago and no problem. Battery failed last week so I replaced it under warranty and now no clock. This pisses me off.
Old 02-27-2019, 09:42 PM
  #522
David68
Support Corvetteforum!
David68's Avatar
Well, add me to the list. Disconnected the battery last week for 3 or 4 days to replace the A6 trans cable and the shifter lock switch in my '08. Two things that we shouldn't have to do. Reconnected yesterday and noticed no clock. I have GPS and all other functions but, no clock. Car has nav, xm, Onstar (inactive). I'll make the call and look into the FB page.
Great info here.
Thanks guys...
Old 02-27-2019, 10:30 PM
  #523
LS14ME2
LS14ME2's Avatar
Lost mine today. Took it in to the foremost Chevy dealership in the bay area that works on Vettes. I have an 07 and the clock was fine driving up to the dealership. They must have noted my clock was working and due to the laundry list of work to do would need to dis-connect the battery, They actually called me to advise me that there would be a good chance that I would lose the clock and there was no fix as of yet. I found this thread and now see I am not the only one. Sure enough, they let me know it was now gone. If there was a fix, these folks would have known about it. Looks like we have to wait for a fix at this point or keep our fingers crossed this date in April works. They did let me know that some cars clocks just come back out of nowhere.
Old 02-28-2019, 02:57 PM
  #524
Oh Boy
Oh Boy's Avatar
What I don't get is that there are people in this thread who knew about this problem before hand and still go ahead and dis-connect their battery and loose the clock. What sense does that make. Can't you buy one of those $10 gizmos with the 9 volt battery in it that keeps your settings while you are disconnecting your battery?
Old 02-28-2019, 03:29 PM
  #525
LS14ME2
LS14ME2's Avatar
From what I understand, the 9V gizmo you reference will not keep the radio from losing the clock, it would have to be a full 12V and mirror a real battery. There are many instances where, depending on the work needing to be done, there should be NO battery voltage at all in the system.
Old 02-28-2019, 04:31 PM
  #526
tshirtmeister
tshirtmeister's Avatar
So True, This 9V Battery is a total Ex Wives Tale! The minute you disconnect the 12V battery the 9V will drop to its short circuit voltage and ya clock goes poof!
Old 02-28-2019, 04:35 PM
  #527
tshirtmeister
I still wonder why some 2005-2010 Nav aren't affected? Is there a Battery in the nav head to keep the firmware safe? Radios and More said no. We need the Sherlock Holmes of Corvettes here!
Old 02-28-2019, 08:40 PM
  #528
jimijam
jimijam's Avatar
Here's what you don't get. Some people work on their vehicle or take it in for service that requires the battery to be disconnected. Others simply discover a dead battery and have to remove it from the car to charge or replace. YMMV.
Old 03-01-2019, 10:04 AM
  #529
StingBeeZ06
StingBeeZ06's Avatar
I think you might be only referring to people who live in areas where the cars are put away for months during the winter. What about TX, CA, FL, LA, MS, etc. where the cars are driven year round? The relevant question is not whether you know about the issue, then disconnect the battery which triggers the clock issue. That would be simply treating a symptom. The REAL question is WHEN will GM provide a fix for THEIR software / hardware issue that is causing all these issues.
Old 03-01-2019, 10:15 AM
  #530
MikeBC
4th Gear
MikeBC's Avatar
Default Me too
Add me to the list, 2007 with bose/nav - clock inop after changing battery. This is a fun game.
Old 03-01-2019, 10:19 AM
  #531
StingBeeZ06
As a side note. The "forced" clock programming, using the "secret" programming code for the Tahoes and Suburbans does work.
Old 03-01-2019, 10:23 AM
  #532
EVRose
EVRose's Avatar
I've had my battery disconnected (05) numerous times and never had a problem with the clock even losing the correct time. For the one's who lose the clock is this something that never happened before when you had your battery disconnected and now all of a sudden it's a problem? Wouldn't that mean something had to change in the HU between the time it was ok with disconnected battery and now? What else could that be except for an internal battery that failed? I don't get it.
Old 03-01-2019, 10:30 AM
  #533
StingBeeZ06
It is not the radio memory that is a problem, all the presets remain after the battery is disconnected.
Something in the software / firmware stopped recognizing the clock feature on or about 12-23-2018, but the clock remained operable. However, anyone who disconnected / reconnected their battery after that date, has lost their clock function. So, if your radio is in the affected group and you disconnect your battery now, you will likely lose your clock.
Old 03-01-2019, 10:35 AM
  #534
EVRose
EVRose's Avatar
Originally Posted by StingBeeZ06
It is not the radio memory that is a problem, all the presets remain after the battery is disconnected. It seems to be affecting 07 and newer.
If you push the clock "button" does the date still show up at the top and is it accurate?
tshirtmeister (03-01-2019)
Old 03-01-2019, 10:38 AM
  #535
StingBeeZ06
I don't know if that function is affected. But I am sure someone will chime in.
Old 03-01-2019, 11:18 AM
  #536
tshirtmeister
Uhm `05s are affected as I threw my HU in the TRASH #15233090. LOL. Then I installed a 2012 USB HU. Now Im Happy all fixed and upgraded!
Old 03-01-2019, 11:35 AM
  #537
StingBeeZ06
Thanks! I corrected my post!
To "C6 from 2005-2010 navigation radio clock stops after battery disconnect
Old 03-01-2019, 12:15 PM
  #538
bbobb401
bbobb401's Avatar
I spoke with a GM advisor 1-800-222-2020, he had heard of the issue and he suggested that OnStar needed to send a refresh to my radio. I asked him if it mattered if I had an OnStar subscription or not, he didn't know. The GM transferred sent me to OnStar, OnStar tech said it wouldn't help. Sent me back to GM tech support...they are worthless.
Old 03-01-2019, 12:38 PM
  #539
A1958R
A1958R's Avatar
Took a drive to my local Cadillac/Chevrolet dealer & spoke to a service writer, he said there is a bulletin concerning the loss of the clock, but it is still undetermined what it is or how to fix it.
They also have a 2012 GS on the lot that had a battery go dead & he said the clock is also gone on it. That was the least of their problems, they forgot to index the window & it was partially down during a heavy rain storm here in Northern California.
Old 03-01-2019, 12:56 PM
  #540
Z06_Bandit
Z06_Bandit's Avatar
whats the magic date? Is it April 29,2019? Is that the satellite "re-sync" date?
Quick Reply: "C6 from 2005-2010 navigation radio clock stops after battery disconnect
