mirror problems help
Old Dec 21, 2018 | 08:42 AM
teddycarnut's Avatar
teddycarnut
Default mirror problems help
My outside mirrors will not hold the settings. Each time I start engine I must readjust manually. I have the memory system in use. Both mirrors go down as if I put into reverse. Please help. Automatic transmission if that matters. It has always worked before.
Old Dec 21, 2018 | 09:02 AM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Put the mirror toggle switch in the door panel in the center. They should not move to curb function then.
Old Dec 21, 2018 | 04:22 PM
teddycarnut
did not help moving toggle to center
Old Dec 26, 2018 | 09:34 PM
HONEY's Avatar
HONEY
1st Gear
Mine move down when I put it in park instead of reverse. Then I have to manually adjust them, as they don’t adjust back when I shift into drive. Moving the mirror toggle to the center position doesn’t help, they still move. I was told this could be a shifter cable issue...
I have a 2007 with automatic trans
Old Dec 29, 2018 | 08:55 AM
corvettezman
My driver mirror just started doing the same after a visit to the dealership. Not sure what those fuggers did to the car.
I put the car in Park, re-adjusted the mirror, then pressed and held the #1 setting until it beeped and learned again. Problem solved for now.
To mirror problems help
