Help with C6 Auto Trans. Shift Interlock Selenoid
Old Jan 1, 2019 | 11:27 PM
Edshore007's Avatar
Edshore007
Default Help with C6 Auto Trans. Shift Interlock Selenoid
I am having a problem getting my auto trans shifter out of Park at times. Believe it could be the shift interlock selenoid going bad. Have not been able to find a replacement part on any of the GM Parts web sites. Would like any help with my problem or finding a replacement selenoid or shift assembly. 2007 C6 auto trans base model convertible.
Old Jan 2, 2019 | 06:52 AM
07MontyRed's Avatar
07MontyRed
St. Jude Donor '07 thru '26
NCM Lifetime Member
There are lots of threads on the Forum on how to simply disable it; you might go that route instead of replacing it.
https://www.corvetteforum.com/forums...k-finally.html
Old Jan 2, 2019 | 08:59 AM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default Shifter
I have a used shifter assembly from my 08 minus the **** cap for sale. PM me for info.
Old Jan 2, 2019 | 02:36 PM
Edshore007's Avatar
Edshore007
Thanks. I will try to disable the interlock first. If that does not work I will contact you about the part.
Old Jan 2, 2019 | 07:46 PM
jbripps's Avatar
jbripps
Hi - I cut mine over the summer - issue is gone. You will need to be mindful that the car will shift without depressing the brake, but for me, that action is automatic anyway. Not an issue.
Jon
To Help with C6 Auto Trans. Shift Interlock Selenoid
