power window will not go back up
Old Jan 10, 2019 | 04:20 PM
Gscafidi's Avatar
Gscafidi
Default power window will not go back up
I have 2006 Corvette and the drivers side window switch will lower the passenger window but will not raise it. I replaced the driver switch with a new one but have the same problem. Is there a fix for this? thanks George
Old Jan 10, 2019 | 07:37 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
https://www.rockauto.com/en/catalog/...assembly,15596
Old Jan 14, 2019 | 02:29 PM
TOM WELCH's Avatar
TOM WELCH
try the window memory reset procedure, if not probably the regulator assembly
Old Jan 14, 2019 | 09:42 PM
Gscafidi's Avatar
Gscafidi
Already tried that. Thanks
Old Jan 14, 2019 | 10:35 PM
Cherokee Nation's Avatar
Cherokee Nation
Can you raise it with the passenger switch??
Old Jan 17, 2019 | 03:07 PM
Gscafidi's Avatar
Gscafidi
yes
Old Jan 18, 2019 | 07:12 AM
3X2's Avatar
3X2
Have you tried it with both doors closed?
To power window will not go back up
