Clutch Question
Old Jan 19, 2019 | 10:26 PM
H8tulooze's Avatar
H8tulooze
Default Clutch Question
Yes I did a search... I have a new stock ZR1 clutch and slave. Do you have to clearance the stock GM slave or just install it.
Thanks!
Old Jan 20, 2019 | 02:46 PM
HorsePowerAddicts's Avatar
0HorsePowerAddicts
Former Vendor
Ideally you should measure every time to make sure your clearances add up. Nothing worse than having a high or low clutch pedal after install and always wondering what the clearances were. Id only takes 5-10 mins to measure.
Old Jan 20, 2019 | 06:18 PM
H8tulooze's Avatar
H8tulooze
Do you have the specs? I watched a couple of videos, I just want to make sure.
I have a LS9, LS9 clutch, LS9 slave and a TR6060 from a Camaro.
Thanks for the info!!!
Old Jan 20, 2019 | 07:40 PM
Dano523's Avatar
Dano523
Should have a free gap of around .130" between the TB bearing face pushed all the way back, to the face of the clutch pressure plate fingers.
Go to post 35
https://www.corvetteforum.com/forums...uestion-2.html
Old Jan 20, 2019 | 08:33 PM
H8tulooze's Avatar
H8tulooze
Go to post 35
Thanks, I see this applies to Tick performance. Does this also apply to Stock GM Clutch and TO?
Old Jan 26, 2019 | 06:35 PM
Dano523's Avatar
Dano523
Yes, since as the clutch wears, it going to decrease the free gap.
So the .130" range is the amount for clutch wear, and the amount that the spring on the TB can take up without having problems with the seal on the slave pushed too far forward at spring take up as well. Hence you don't want more than .150" or your going to have problems with the slave at full throw that may start leaking, and you don't want under say .110", since it going to be board line as the clutch wears and the pressure pressure finger move back at the end of clutch life, with the slave spring coil bound up for the clutch and the clutch not fully engaging instead.
To Clutch Question
