Alignment after shocks and sways?
Old Jan 24, 2019 | 09:56 AM
old motorhead's Avatar
old motorhead
Default Alignment after shocks and sways?
Just changed the shocks and sway bars on my 2013 C6 narrow body. Went from stock stuff to Z51 sways and Z06 shocks with a lot of engine work too. Car drives straight. The weight probably changed a little from removing the stock exhaust and adding LT's, non catted mids and Z06 mufflers. Do I need to have the alignment checked? The alignment was done 8 months and 3K miles ago.
Old Jan 24, 2019 | 11:36 AM
Kenny94945's Avatar
Kenny94945
IMO debatable.
Changing shocks or sway bars should not affect alignment IMO.
But, if you went to an after market shocks and with your comments about a weight change,
those changes could produce a ride height change.
If height changed, then I'd say, yes re-align.
Old Jan 24, 2019 | 12:46 PM
TucoTom's Avatar
TucoTom
Recently had shocks & sway bar replaced, shop said alignment wasn't necessary.
Old Jan 24, 2019 | 04:06 PM
timd38's Avatar
timd38
If you put coilover shocks I would, only because the ride height would have changed, but I was not align it if they just replacements. Nothing has changed since shock manage the ride, but don't carry the load, unless they are coilovers.
To Alignment after shocks and sways?
