Compression ratio
Old Jan 27, 2019 | 12:29 AM
jus1975's Avatar
jus1975
Default Compression ratio
Does anyone know what is a stock ls3 compression ratio. I'm reading 68cc and 70cc
Old Jan 27, 2019 | 09:14 AM
Patriot Six's Avatar
Patriot Six
68cc combustion chamber and 10.7:1 compression ratio.
Old Jan 27, 2019 | 10:24 AM
jus1975's Avatar
jus1975
That's what I thought but now I'm seeing 70cc in a few books I have. And specs on the heads are advertised with 70cc at summit and jegs and a few other places
Old Jan 27, 2019 | 11:09 AM
Patriot Six
That’s probably aftermarket heads.
Old Jan 27, 2019 | 11:29 AM
jus1975's Avatar
jus1975
Nah. It was gm
Old Jan 27, 2019 | 11:54 AM
veneno's Avatar
veneno
I sent me heads to texas speed earlier in the week and asked them to mill the heads down to 66cc
He said the stock ls3 heads are 70cc
Old Jan 27, 2019 | 12:00 PM
jus1975's Avatar
jus1975
see what i mean. 2 different sources. 2 different measurements. Im confused. SPS says they are 68cc. Im dying over here
Old Jan 27, 2019 | 01:10 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
LS3 Cylinder Heads . . . .(0821 Casting)
Intake Valves: . .. - . 2.165" Hollow Stem Stainless
Exhaust Valves: . .. . 1.590" Solid Stem Stainless
Head Chambers: .. .. 70cc
Old Jan 27, 2019 | 01:24 PM
old motorhead's Avatar
old motorhead
What's the end game here? Why does it matter? If you remove a similar amount during the milling process or add a thinner head gasket, the results are not going to differ that much.....whether 68 or 70cc.
Old Jan 27, 2019 | 01:26 PM
jus1975's Avatar
jus1975
I have a set of used heads i bought that are 72cc. So i wanted to mill them down to stock maybe less. But I cant find out exactly what stock is
Old Jan 27, 2019 | 01:48 PM
Turbo6TA's Avatar
Turbo6TA
68cc or 70cc ....... Split the difference and call it 69cc
"Close enough for government work"
To Compression ratio
