2007, 63k
Old Jan 27, 2019 | 02:46 PM
rudutch's Avatar
rudutch
Default 2007, 63k
changed out today, (yes it was a 2+ hour bitch) last 2 times run was through warm up in the garage, coloring seems off
Old Jan 28, 2019 | 10:35 AM
TucoTom's Avatar
TucoTom
Google "Spark Plug Visual diagnosis", or click "YouTube".
What spark plugs did you use as replacements?
Old Jan 28, 2019 | 10:45 AM
rudutch's Avatar
rudutch
same (oem)
Old Jan 28, 2019 | 11:01 AM
TucoTom's Avatar
TucoTom
The reason I ask is the new OEM ACDelco are 41-110 (12680072).
Old Jan 28, 2019 | 11:06 AM
rudutch's Avatar
rudutch
Acdelco41162
Old Jan 28, 2019 | 01:19 PM
TucoTom's Avatar
TucoTom
Per ACDelco 41-110 was replaced by 41-162. Name change only, no difference in plug.
Old Jan 28, 2019 | 01:37 PM
Kenny94945's Avatar
Kenny94945
Does look rich.
But, as I understand, OP states last time the engine was run it was idling for extended period?
FWIW Replacing at 63K is not a bad thing, can research Utube etal for gap/ puck wear/ etc. and
if the engine is stock, I'd again replace with OEM spec.
Old Jan 28, 2019 | 01:50 PM
rudutch's Avatar
rudutch
12 years, I was worried about thread seizing, they have some type of anti-seize on them, so that was easy.
Getting the plug wires off the plugs was very difficult my hands look like I got in a fight with a cheese grater.
The have plenty of dielectric grease on them now
Old Jan 28, 2019 | 02:43 PM
jaredtxrx's Avatar
jaredtxrx
Curious, do you have an modifications?
Do you use any fuel additives like Techron or octane boosters?
They look on the rich side to me as well.
Mine at ~120k
Old Jan 28, 2019 | 07:05 PM
rudutch's Avatar
rudutch
Curious, do you have any modifications?
Corsa axle back
it has a bunch a stay-bil in it
once spring rolls around and I can actually drive it, I will pull an easy one and re-check after a couple tanks of gas
Old Jan 29, 2019 | 10:09 AM
jaredtxrx's Avatar
jaredtxrx
Corsa axle back
Corsa axle back
This *could* be causing the richer mixture but I wouldn't think so with just an axle back. An air intake maybe.
This is probably why they have that reddish color to them, no biggie.
I'm also a little concerned about how much oil is on the threads. What are your driving habbits like? May be in the need for an "Italian Tune-Up" once in a while to blow some stuff out of there.
To 2007, 63k
