Unless you change the OEM for a true CAI at the dragstrip and convert the MPH to HP, you'll never know how much one will gain. I can tell you my racing buddy Bob (RIP) gained .15 seconds with his LS2 after I did the $2 shroud prop at the track. He also gained 2 MPH. I don't have his timeslips to confirm the exact MPH difference. https://www.corvetteforum.com/forums...post1586336347
No real benefits in power from an airflow perspective as the factory C6 intake flows plenty from the factory. Most cars mainly benefit from intakes that have a shroud to isolate the intake from sucking in heated air from the engine bay or those intakes that pull air from outside the engine compartment. But it really isn't a power gain, it is just preventing power from being robbed because of ingestion of hot engine compartment air.
This! I think timing starts to get pulled once the IAT reads higher than 80 something degrees.
LS2 - you will likely gain a little power but a tune will really unlock the gains.
LS3 - waste of money until your going throttle body, intake manifold, headers, cam, etc...
Headers will give you a better bang for the buck, even going with a complete Z06 header back exhaust is a great option for power with "minimal" money spent.
When you say "header back", are you meaning the complete Z06 system which would include exhaust manifold back?
CAI are one of those supporting mod things you do, an "every bit helps" type deal. Dont count on really feeling it and hoping it was worth it
There are simple things that work, and others that work in theory or in a dyno cell but dont do anything in real life pulling a car behind it.
Halltech is the only product line that has documented gains on a dyno as far as I know. Most of that is from moving the MAF forward and the Beehive heat shield to keep the hot engine air out of the intake. As stated before this is done due to the fact that the intake temps go beyond 86 degrees the engine starts to pull timing. That is not a good thing for performance. Katech and others use these on their performance builds so they must have some merit.......
As mentioned, the LS2 will benefit more with an aftermarket CAI than the LS3. The LS2 air intake is much more restrictive than the LS3. A tune after a CAI will benefit both the LS2 and LS3. If you decide to go with headers or Z06 exhaust, then install the CAI, exhaust and tune last. If you go with all three, your tuner will most likely recommend a 160* t-stat and reprogram the fan duty cycle to help keep the average coolant temps down. So what you are trying to accomplish is more cooler air into the engine while keeping combustion chamber temps down and allowing more exhaust out. These changes will maximize the benefits of a tune. Expect around 28+ rwhp for all three mods, depending on the dyno.
