Diagnostic code P1825
Old Feb 8, 2019 | 05:38 PM
Bguilmino's Avatar
Bguilmino
6th Gear
Default Diagnostic code P1825
Anyone have any experience with this code? I got this while driving using the paddle shifting. After restarting, the car ran fine but still shows the engine warning light.
Old Feb 8, 2019 | 05:57 PM
crusher1's Avatar
crusher1
One forum member said this:
Try this I had a few Corvettes with this problem. Remove the wiring connector on the right rear of the transmission and reinstall. Sometimes the connection can be weak. Be careful the connector has a lock then twist.
Check the number one fuse under the hood or it might be number 3 fuse for connection I can't remember which right now. Which ever says TCM.
Chris
Old Feb 9, 2019 | 08:11 AM
Bguilmino's Avatar
Bguilmino
6th Gear
Thanks for the suggestions. I will give it a try.
To Diagnostic code P1825
