2005 c6 diff leaking!
Old Feb 10, 2019 | 11:01 AM
Spitefire1's Avatar
Spitefire1
Cruising
Default 2005 c6 diff leaking!
Hey guys what’s up! Looking to swap out myrear diff for a stronger case. I hear that I can get. A 3 rib c5 zo6 rear and bolt up. Just need the custom diff bracket? Does anyone know who makes these brackets. And what else is need to be done. What are my options? I’m new to this and would like to do this sooner than later. Any info would help. Thanks guy!
Old Feb 10, 2019 | 11:52 AM
jim2092's Avatar
jim2092
Veteran: Marine Corps
St. Jude Donor '08
Do a search of this forum section using several combinations of the item you want. There was a thread or two on how to make this item several years ago.
Old Feb 10, 2019 | 12:06 PM
Spitefire1's Avatar
Spitefire1
Cruising
Does anyone make that diff bracket. Heard stranger660 made the bracket Anything could help
Old Feb 11, 2019 | 06:36 AM
jim2092's Avatar
jim2092
St. Jude Donor '08
stanger383 - https://www.corvetteforum.com/forums...rear-diff.html
Old Feb 12, 2019 | 08:20 AM
Fly N Low's Avatar
Fly N Low
I just upgraded my 05. RPM Transmissions in Indiana can hook u up with the whole kit in any gear ratio u want.
Old Feb 14, 2019 | 09:08 AM
jim2092's Avatar
jim2092
St. Jude Donor '08
That is the exact route I took with my 2005 ('06+ case with 4:10) from RPM. But have been led to believe the C5 ZO6 case is even stronger. The '05 case is weak.
Old Feb 14, 2019 | 10:50 AM
Fly N Low's Avatar
Fly N Low
That would be a good question for the guys at RPM. I know they use the Z06 stub shafts in the stage 2 rear I got from them with 410's also. I'm sure they can build a rear for any HP level.
To 2005 c6 diff leaking!
