Need some guidance
Old Feb 12, 2019 | 05:08 PM
Chad Primeaux's Avatar
Chad Primeaux
7th Gear
Default Need some guidance
Need some input. My C6 '11 GS which has a Lingenfelter cam, headers, not cats, 3"exhaust running through NPP Z06 mufflers has a check engine light on. I was told when I had it dyno'd that I needed to change my O2 sensors and that should clear up the check engine light. Well, I changed the two front O2 sensors out with new extensions and the back two were deleted when dyno'd. Check engine light went away, then reappeared after about 40 miles. Still reading lean on banks 1 and 2. MAF sensor taken off and cleaned with sensor cleaner and reinstalled. No intake leaks were detected around the air intake either. Who is recommended to diagnose the issue or tweak the computer program to adjust? Also when driving I get a seat of the pants noticeable stumble that kinda feels like a miss sometimes. Thanks in advance for advise/input. Posted on local corvette facebook page. I"'m in south Louisiana, Lafayette area.
Old Feb 12, 2019 | 08:29 PM
MTPZ06's Avatar
MTPZ06
Sounds like a crap tune...but without proper diagnostics, tough to say. Here: https://www.corvetteforum.com/forums...louisiana.html
