Active Handling no display
Old Feb 24, 2019 | 03:03 PM
bent2's Avatar
bent2
Default Active Handling no display
Yesterday my battery went dead in my 08 c6 z51. I had to jump start it with one of those jump boxes. Since then the active handling has not worked and doesn't even display on the DIC anymore. I have tried disconnecting the battery and then reconnected and I have checked most of the mini fuses. I have no service AH indicated and no codes. Anyone else have this problem? Is there anything else that I can do or check? Thank you for your help
Old Feb 25, 2019 | 01:20 PM
schizcat's Avatar
schizcat
When you cycle through your gauge info, do you see tire pressure on all four tires or do any of them read 0?
Old Feb 25, 2019 | 03:26 PM
bent2's Avatar
bent2
Yes, it was the left rear tire pressure sensor. When that started reading the A.H. started working. It took about a dozen start up cycles for the TPS to start reading. I've had problems with that LR TPS reading 0psi before when ever I reconnected but never seen the A.H. disappear . Maybe that TPS is going bad.
Old Feb 27, 2019 | 05:25 PM
schizcat's Avatar
schizcat
Probably going bad. You can usually go to Discount Tire and have them reset the sensors for free to see if that helps. However, if any of the tires reads 0, then the TC cant be turned off.
To Active Handling no display
