Service active handling system
Old Feb 28, 2019 | 06:21 PM
VICTOR RAMIREZ's Avatar
VICTOR RAMIREZ
2nd Gear
Default Service active handling system
Guys, anyone can help me? The "service active handling system" light appears in my 2005 corvette. I don't know if this happened
when i passes a bump, or due to a noise in the right rear wheel while driving. Sometimes it makes de noise, sometimes not. I already
bought the big bolt that fastens the axle (33mm). Do you think i should change it? The car has only 20,000 miles.
Also, another light goes on: " check brake fluid" and the warning light also goes on. I had already check the fluid level and is ok.
Should i make a change of the fluid due to the age of the car (13 years)?
