HELP! Chirp after cam install.
Old Mar 12, 2019 | 12:21 AM
ltdriser's Avatar
ltdriser
Default HELP! Chirp after cam install.
I just installed a BTR stage 3 cam with new springs and pushrods. Along with a new oil pump, new timing chain, new ls7 lifters and head gaskets. This was my first time doing anything this large. I started it and initially thought I was good to go but I have a semi concerning sound coming from the driver side. What does it sound like to you guys? And should I be worried. I'll note my header to cat right now is not fully tightened.
https://youtu.be/rBO-UmBZ_5o
Old Mar 12, 2019 | 10:37 PM
Silver c6 z-51's Avatar
Silver c6 z-51
Did you replace the harmonic balance, I didn’t see your video but chirping usually indicates a belt squeal from the balancer slipping under a load.
Old Mar 12, 2019 | 11:49 PM
ltdriser's Avatar
ltdriser
Yeah, I replaced Harmonic balancer as well. I took the serpentine belt off today, tightened the headers to the cat and ran it again to check for the sound. The sound is still there. I'm curious if if takes a little bit for things to "settle in". I haven't got the engine up to temp yet just because the sound has me a little nervous.
Old Mar 13, 2019 | 12:05 AM
Silver c6 z-51
Also check your spring loaded belt tensioner, I switched mine to a Katech static one.
Old Mar 13, 2019 | 12:20 AM
ltdriser's Avatar
ltdriser
Running with no belt and still getting the sound would indicate that it's not pulley related. I'm just a little nervous since this was my first build.
Old Mar 13, 2019 | 01:00 AM
JonnyCap's Avatar
JonnyCap
If you still can't pinpoint it, I'd buy a stethoscope from Harbor Freight and poke around the engine.
Old Mar 13, 2019 | 04:45 PM
MTPZ06's Avatar
MTPZ06
This...they sell them for under $10 IIRC.
Old Mar 13, 2019 | 08:40 PM
ltdriser's Avatar
ltdriser
I grabbed a stethoscope and header gaskets(didn't replace them for whatever reason). I also rented a coolant pressure tester to check head gaskets and a borescope.
So far I've checked the coolant system, very little leakage over an hour. I'll pull plugs and do it again tomorrow, hoping to rule out any head gasket leak. Also when I pull plugs I'll stick scope in there and have a peak. Next I'll pull valley cover and again take a look at everything with bore scope. If all is well I'll throw it back together, slap the gaskets on it, torque them down and send it. I'm probably being overly sensitive. I should really get a base tune in there to rule out anything of that nature. Off idle it doesn't seem to have any noise, only when it's at it's rough untuned idle.
Old Mar 14, 2019 | 07:49 AM
old motorhead's Avatar
old motorhead
I'd vote header gasket not sealing.
Old Mar 14, 2019 | 08:34 AM
ltdriser's Avatar
ltdriser
Last night I went ahead and pressure tested without the plugs. It wasn't losing any noticeable pressure. I left it pressurized over night and this morning it was down 1.5 psi. I'm not really worried about that.
I took the valley cover off last night to take a look at visible cam/rollers. They all look pristine so I'm hoping the other 8 are in the same shape.
I took the borescope and took a look in the spark plug holes at the Pistons. No coolant or anything in there but tons of carbon build up. I'm going to attribute that to the fact that I don't have a tune.
I'm thinking it's the header gaskets, I reused old ones that I believe were original. 100k miles on them. And I may have swapped the passenger and driver side gaskets when reassembling. I didn't mark them like I should have when I took them off.
Old Mar 14, 2019 | 10:43 AM
cv67's Avatar
cv67
St. Jude Donor '05
There is no settling in, something is wrong. Keep us posted
Old Mar 14, 2019 | 10:52 PM
Medicdiver's Avatar
Medicdiver
St. Jude Donor '13
Have seen lifter rollers cause a chirp like a belt squeal. There is a TSB for the trucks with the 5.3/6.2 with this problem.
Old Mar 14, 2019 | 11:06 PM
Kingtal0n's Avatar
Kingtal0n
aren't ls7 lifters notorious for bleeding down when faced with large amounts of spring pressure and making noise...
Old Mar 16, 2019 | 08:38 AM
double06's Avatar
double06
Make sure you take the AC belt off also when you do your belt test.
Old Mar 16, 2019 | 12:16 PM
Owenco's Avatar
Owenco
Sounds more like an exhaust/header leak to me, but the video is pretty dang short. Get new OEM header gaskets to start and new header to cat gaskets(not sure what manifolds/setup youre using) But exhaust leaks can make some very confusing noises as theyre never uniform. Btw, that doesn't sound like a belt at all.
Old Mar 16, 2019 | 04:08 PM
Huskerman's Avatar
Huskerman
2021 C6 of the Year Finalist - Modified
Check your alternator.....I have one go bad that was making a chirping noise when it went......... opps I see you took the belt off and ran it.......nevermind!
Old Mar 16, 2019 | 06:28 PM
old motorhead
If you want to isolate the source of the chirp, pull a spark plug wire off one at a time. The offending cylinder will be quieter if it's not firing. That's assuming you do have a header gasket not sealing. Identify the source and you may have to change just one header gasket. If the other side is quiet, there's no reason to change that gasket.
To HELP! Chirp after cam install.
Old Mar 17, 2019 | 05:19 AM
rajahhindi's Avatar
rajahhindi
Did you take the AC belt off too? A chirp is usually belt related, if we all think the same noise? I'm so over
gatorback /continental belts chirping. Some people have great results, but I am the opposite. Just listening
to my vette this morning with the gatorback on cold start, I wanted to kill it with its chirp! And yes, I checked the alignment.
Had the same results on the main blower system. Changed belt and gone no more chirpy. I live in Australia and I cannot just get
a belt tomorrow that fits! You are sooo lucky living in a country with multiple acess to belts. Hey Sammy?
Old Mar 18, 2019 | 02:49 PM
RlySlow's Avatar
RlySlow
following to know what you find out.
I just started mine for the first time yesterday, fresh TMS 370 block, A&A v3 t-trim, and EPP Blower cam and I swear it has exactly what you're describing from the passenger side. Sounds like a pulley chirp but definitely sounds like it's in the middle of the passenger side - from the head-ish area. Sometimes it goes away though. It was loud on first start then now when i hear it it's quieter.
Old Mar 18, 2019 | 08:09 PM
ltdriser's Avatar
ltdriser
So my conclusion is: it's normal. I'm pretty sure it's a mix of no tune and headers noise. I've done literally everything I can without lifting the heads or pulling the cam back out. My friends seem to think I'm crazy thinking something is wrong they all think it sounds fine. If you take a step back and not stick your head in the engine bay it'll sound like a normal car. I think I was honestly chasing a ghost.
I have poked around with a stethoscope and listened to every square inch of the engine. I've pulled the intake and inspected the visible cam lobes/lifters. Taken a look at rockers. Pressure tested the coolant system with plugs out to test head gasket integrity. All of these tests came up with nothing. Everything seems to be in good working order.
What I have done, which also gave me a huge bit of relief, was browsed youtube and took a good listen to all the non-tuned first start videos of ls engines. That sound seems to be prominent in almost every video. Take a listen to those cars and get back to me. Tell me your thoughts. I have more videos I can upload if anyone is interested. I'm getting it tuned next week.
