What oil to use?
Old Mar 24, 2019 | 06:50 PM
southofHoustonVette's Avatar
southofHoustonVette
Default What oil to use?
What type. Brand. And weight do people use 2010 c6 base
Old Mar 24, 2019 | 07:25 PM
BadAV's Avatar
BadAV
Any oil that meets the requirements in the owner's manual is fine. I am partial to Pennzoil Platinum 5W30 since it's a really good oil that you can buy about anywhere, and it meets the requirements.
Old Mar 24, 2019 | 07:42 PM
southofHoustonVette
Sweet
Old Mar 24, 2019 | 09:20 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Any 5W-30 Synthetic ....
I use Mobil 1, but any other quality 5W-30 Synthetic will be fine.
See how easy that was ...
_______________________________
Note: Don't use Lard ... I have found that it just gets too thick when it gets at a cold temp... But lard does work great when making home-made breakfast biscuits !
Old Mar 24, 2019 | 09:33 PM
farmington's Avatar
farmington
I buy Mobil1 when it’s on sale at Costco. Usually about $25 for 6 qts.
Old Mar 25, 2019 | 03:15 AM
Matt Zed's Avatar
Matt Zed
Definitely a great oil
Old Mar 25, 2019 | 07:17 AM
boonie c4's Avatar
boonie c4
Walmart syntech 5w30 oil $17.00 for 5 qts of synthetic oil and it's rated 1 level higher than the original specs.
I understand that Quaker state is the oil's maker, but I haven't been able to confirm this statement.
Old Mar 25, 2019 | 08:23 AM
southofHoustonVette
I guess I am asking because I had a guy telling my that ams oil is the best and only oil to use. I ran royal purple for years in my diesel but the quality has went down. Just want to make sure I put a quality oil in
Old Mar 25, 2019 | 10:39 AM
TLS_Addict's Avatar
TLS_Addict
+1 for this.
Old Mar 25, 2019 | 04:51 PM
timd38's Avatar
timd38
Red Line 5W30.
Old Mar 25, 2019 | 07:19 PM
sobe88's Avatar
sobe88
Stock I ran Mobil 1 5w30, currently run Amsoil 20w50.
Old Mar 25, 2019 | 11:48 PM
southofHoustonVette
Why the change ?
Old Mar 26, 2019 | 07:56 AM
sobe88's Avatar
sobe88
Originally Posted by Kenny Hammond
Why the change ?
402 stroker makes much more heat, then throw in bearing clearances via my engine builder and while we tried 10w30, idle pressure was 21-23psi. Bumping up to 20w50 brought my oil pressure up to 35-38 idle.
Old Mar 27, 2019 | 05:46 AM
KingCorvette93's Avatar
KingCorvette93
To What oil to use?
