Ever see this before?
Old Mar 27, 2019 | 03:48 PM
09C16Callaway's Avatar
09C16Callaway
Cruising
Default Ever see this before?
Crane cams said it’s a one in 10 million chance. Lucky me?
Old Mar 27, 2019 | 04:07 PM
Matt@Tick's Avatar
0Matt@Tick
Former Vendor
It looks like the back of the rocker has broken off. That is a pretty normal issue with an aluminum rocker like this on an LS engine. This is one reason everyone always recommends using the factory rocker with a trunnion upgrade.
Old Mar 27, 2019 | 08:10 PM
09C16Callaway
Cruising
I guess crane cams was blowing smoke up my @#$ then. Should I be expecting this to happen again?
Old Mar 27, 2019 | 08:12 PM
73DBG's Avatar
73DBG
Not if you go back with stock rockers or shell out the big money....
Old Mar 28, 2019 | 12:34 AM
09C16Callaway
Cruising
Callaway says these are stock rockers. Now what? Ughh...
Old Mar 28, 2019 | 02:00 AM
73DBG's Avatar
73DBG
These are factory rockers with the CHE upgrade.
Old Mar 28, 2019 | 09:59 AM
Matt@Tick's Avatar
0Matt@Tick
Former Vendor
You need a set of OEM rockers. Crane is not the OEM rocker arm for an LS engine. You can get them new, or just find a good used set, then install the trunnion upgrade.
Here is a link to the trunnion kit. https://www.tickperformance.com/tick...ll-ls-engines/
You can also get these rockers that are already gutted and ready for the bushings, they come as a set of 8.. https://www.tickperformance.com/summ...-upgrade-kits/
There are also more options out if this is not something you want to do yourself. You can give us a ring and I will be happy to point you in the right direction.
Old Mar 28, 2019 | 11:25 AM
73DBG's Avatar
73DBG
OP hit Matt up man! All the guys at Tick Performance are rock solid! I honestly don’t think you’ll find better customer service in the industry! They went above and beyond for me and I’m no special that’s for sure! Someone is giving you some bad info that’s for sure. Good luck bro🇺🇸
To Ever see this before?
