Spit/Backfire on wot LS3
Old Mar 27, 2019 | 08:39 PM
Rebel_1's Avatar
Rebel_1
4th Gear
Default Spit/Backfire on wot LS3
Right now I have CAI, Headers, Catless x-pipe and tune. Tune was about a month ago, recently when I go wot I get an intial spit/backfire that causes a slight hesitation before my car takes off. Any idea what might be causing this? I thought about switching the plugs but I’m not sure, any help is appreciated.
Old Mar 27, 2019 | 10:22 PM
GUM3Y's Avatar
GUM3Y
I’ve seen a dirty mass air sensor cause this. Buy the special cleaner from your local parts store and give it a try.
Old Mar 27, 2019 | 11:27 PM
DAMCars's Avatar
DAMCars
Check the coil pack and wiring harness too.
Old Mar 27, 2019 | 11:44 PM
HOXXOH's Avatar
HOXXOH
Also check your plugs. The backfire can mean that the iridium tip just broke off. Running too lean maybe.
Old Mar 28, 2019 | 06:57 AM
irok's Avatar
irok
More often than not problem is plug wire or plug when engine is under load such as wot.
Old Mar 28, 2019 | 10:17 AM
Rebel_1's Avatar
Rebel_1
4th Gear
Thanks all, I’m going to try the NGK TR6 plugs and see how they work
To Spit/Backfire on wot LS3
