Base c6 .. hp realistic numbers
Old Mar 30, 2019 | 05:08 PM
southofHoustonVette's Avatar
southofHoustonVette
Default Base c6 .. hp realistic numbers
What are some realistic numbers you guys have got from normal bolt one and minor upgrades???
Old Mar 30, 2019 | 05:29 PM
jchappies's Avatar
jchappies
depending on your trans an LS3 starts at about 355-365rwhp as a base tune (obviously location and weather will play a roll in your dyno numbers)
What kind of upgrades you looking at?
Old Mar 30, 2019 | 05:55 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Bone Stock LS3:
M6: . 436 SAE Net HP . . -13% Drivetrain Loss = 380 RWHP (SAE Corrected)
A6: . 436 SAE Net HP . . -15% Drivetrain Loss = 371 RWHP (SAE Corrected)
Old Mar 30, 2019 | 05:58 PM
Turbo6TA's Avatar
Turbo6TA
2011 GS / A6
1. Bone Stock = 371 RWHP SAE Corrected
2. Added Headers with Cats and Dyno Tune = 405 RWHP SAE Corrected
3. Then Added a 'Heartbeat' Supercharger @ 7.0 PSI Boost = 535 RWHP SAE Corrected = (Approx. 630 SAE Net HP)
Old Mar 30, 2019 | 07:28 PM
southofHoustonVette
Texas speed headers and X pipe and axel back exhaust. Intake. Tune it and that’s it. I am near Houston so on the coast btw. Just curious what these cars are capable of. When funds allow I would love to charge it or build a stroker.
Old Mar 30, 2019 | 07:30 PM
southofHoustonVette
Alsk I have the automatic so.. A6
Originally Posted by Turbo6TA
Bone Stock LS3:
Old Mar 30, 2019 | 07:57 PM
SixAddict's Avatar
SixAddict
I've got an 09 base, A6, 3LT. Bolted on 1 7/8 long tube headers, catless 3inch x pipe to my stock npp, cai and tuned.
Dyno showed 388 rwhp and 403 torque. The tune definitely brings these motors alive though.
Old Mar 30, 2019 | 08:00 PM
southofHoustonVette
Thats what I was curious about. How much a tune brings the motor alive ? I know I take and exhaust helps to a point but wasn’t sure how much a tune would wake it up or not see much diffence
Old Mar 30, 2019 | 08:40 PM
jchappies's Avatar
jchappies
I gained 20rwhp with just a tune
Old Mar 30, 2019 | 09:20 PM
TLS_Addict's Avatar
TLS_Addict
GM leaves a bit on the table. Tuning helps with power but also helps with torque management.
Old Mar 30, 2019 | 09:53 PM
southofHoustonVette
Yeah right now if I punch it or get on it it doesn’t spin or break them loose. I want the true vette feel Was curious how the torque management would act or hurt
Old Mar 30, 2019 | 10:54 PM
jchappies's Avatar
jchappies
I'm boosted with 550 to the wheels, these motors can handle quite a bit.
With what you have listed you will have no problem breaking the tires loose. The tune will be the key.
Old Mar 30, 2019 | 11:14 PM
TLS_Addict's Avatar
TLS_Addict
Both of my stock LS3 Vettes would tear tires loose with relative ease. Did you turn off TC or active management?
Old Mar 31, 2019 | 12:20 AM
southofHoustonVette
Yeah. I would move it to the competitive drive mode I took off from the gas station and it would spin but not much. I know my cousin had a vette and would spin through second and ask for more. Just made me think if I had it tuned it would be a different car.
southofHoustonVette
Man I hope 🤞
Old Mar 31, 2019 | 12:23 PM
HOXXOH's Avatar
HOXXOH
Spinning is not winning and HP numbers don't directly relate to much without the vehicle they're within.
You first need to seriously assess what your bottom line goals are, before you can create a plan to achieve them with the time, abilities, and finances you have available.
Old Mar 31, 2019 | 04:25 PM
southofHoustonVette
True. And spinning isn’t the goal for sure. Just a reference of how the car was acting For me I will never hit a track I am just a weekend warrior/ date car. And budget is low so will save a purchase when possible
To Base c6 .. hp realistic numbers
Old Mar 31, 2019 | 05:37 PM
HOXXOH's Avatar
HOXXOH
So forget HP numbers, since they are meaningless. Low budget means you need to do the labor yourself. The best bangs for the bucks are:
A higher stall converter (~$900-1000)
Z06 manifolds, down pipes, and H-pipe modified with reducers (~$200-400)
Z06 mufflers welded to your over-the-axle pipes (~$200-400)
The $2 shroud prop
And a tune after all the above is done. (~$400-500)
Don't use the competitive drive mode. It's only valuable if your car is set up for serious track competition. Just do the one button push to turn off TC and then only when launching with good tires.
Have fun, but stay safe.
Old Mar 31, 2019 | 08:07 PM
southofHoustonVette
Ok let’s restart this. Meaning budget meant I will save and do things when possible. I am planning to do Texas speed headers and x pipe with a slp loud mouth axle back. Then tune from me tuning in rosenever. Just curious how much better it will run after all this if any
The $2 shroud prop
Old Apr 1, 2019 | 10:40 AM
jchappies's Avatar
jchappies
With what you have listed you will be over the 400RWHP hump.
