Aftermarket Cats with Headers
Does anyone have any experience with installing aftermarket cats for passing emissions (sniffer)? I'm really just curious as to what cats others have used (Magnaflow, Flowmaster, no-name, etc.) successfully or unsuccessfully. I have fabrication and welding experience, so I could install them, but am unsure what cats to go with.
Note, you only going to loss about 3hp with the high flow cats in play, and even the no name high flow cats work well.
From the back of the header collector flange, you want at least 3" or greater to the honey combs start point of the high flow cats.
To understand this, watch this video on header scavenging, and you will under stand the needed distance back from the header collector you want to keep clear so the collector can scavenge correctly
So that out of the way, measure the OD of the X pipe, pick up two high flow cats that match the X pipe size, and they will be cut in/ mounted in the X pipe after the header collector point on the X pipe.
Next on the list, it a quick check of the tune. The car will hold want to hold an AFR of 14.1 when you are not at WOT, but need to double check to tune to make sure someone does not have it running too rich at WOT that it going to fail the Denver sniffer test. The AFR should be set around 12.6 at WOT, and this will allow you to pass the Denver snog sniffer test with the high flow cats.
Also, since the car has headers on it to begin with, the rear O2 sensors should have been turned off, so no codes will get you through Denver smog as well.
As for muffler, strange duck on some of them, since they can drone like crazy. Hence drone so bad, you rip them off car inside a week. This is the reason that most will run either Borla or Corsa mufflers, since they are the known not to drone.
Edit: My car is tuned and the rear O2 tests are set to complete in the ECM. I do not think you can get any set of headers and high flow cats, even the best high flows like GESI's, to pass, as the rear O2s are in a timed event with the main O2s. The headers change the distance and timing, so very likely you won't be able to get there without tuning.
But since your just tricking the sensors, easier not to install them, then just turn them off in the tune.
Hence front sensors needed for the tune in closed loop, and the rear sensor just check to make sure that the cats themselves are working efficient instead.
With the Rear sensor turned off, then no codes and you pass the OBD II test that is just looking for codes alone.
You can buy their high flow cats separately online.
As for not having to run cats on a C6, not so true, and it just the states that don't run a smog test that you can semi get away with pulling the cats since you will not be checked during yearly smog inspections. Hence push comes to shove, and LEO really want to have its way with you during a pull over, cats are mandated federally and they could go after you for pulling the cats in the first place.
To bottom line it, high flow cats only cost you about 4hp total and they keeps the cabin of the car from reeking of unburnt fuel every stop light.
Random Techs are not good high flows for our OBD-II cars. The GESI units are superior, also cost double, and they are true OBD-II compliant high flows.
EDIT: I should also mention that Random Tech makes metallic (OBD1) and ceramic (OBD2) substrate cats...so choosing the right one is important.
