Heads up Display
Old Apr 17, 2019 | 01:27 PM
VaughnCo's Avatar
VaughnCo
VaughnCo
Default Heads up Display
Hi Guys,
My HUD went out the other day. Any of you have this issue? I have a 2005 Z51. Where would i start to troubleshoot?
Old Apr 17, 2019 | 01:45 PM
PCMusicGuy's Avatar
PCMusicGuy
The first step would be to see if it is a mechanical or electrical failure. If you search for HUD issues on the forum, there is a common one where the mirror somehow mechanically is no longer in the position it needs to be in. Perhaps at night, turn out all of the lights on your car and see if you can see some green glow coming from the HUD. If so, it is likely the mechanical failure. If not, it might just be that the electrical part producing the light has failed.
Old Apr 17, 2019 | 04:38 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
The plastic brackets inside most likely broke.
after 13 years it’s common on cars in high heat areas.
its a big of a pita, but you can pull it without dash removal
To Heads up Display
