Car went dead while driving at night.
Old Apr 18, 2019 | 07:29 PM
Eddie101's Avatar
Eddie101
Default Car went dead while driving at night.
So the other night I was just heading back from a local car show, noticed the headlights flicker a couple of times and the stereo went blank once or twice. After around half an hours drive I pulled upto a roundabout and the car went dead, no headlights dash lights just the engine management light, car started straight back up when I dipped the clutch and pressed start button.
No more problems the next day then I went to start it today and it clicked when I went to start it, tried again did the same, tried a third time and it cracked over fine and started. Couldn’t make it happen again.
I checked the earths around the engine in particular the one near the starter all tight and good. Starter had a rusty connection on the lowest point, so cleaned that up as best I could and tightened back up, not brilliant as I don’t have any ramps to lift the car up.
Could this be a dodgy ignition switch, any other ideas?
Eddie
cars an 06 manual hard top
Old Apr 19, 2019 | 08:24 AM
Eddie101's Avatar
Eddie101
Default Thought I would add a picture of the starter terminals
They look a bit shiny as I wire brushed them up, but not sure if it’s rusty because of getting too hot.
Old Apr 19, 2019 | 10:27 AM
HOXXOH's Avatar
HOXXOH
Before doing anything else, I'd do an alternator test and a battery load test to confirm the main components were working at nearly peak efficiency.
Old Apr 19, 2019 | 12:52 PM
rc51racer's Avatar
rc51racer
agree
Old Apr 21, 2019 | 07:08 AM
Eddie101's Avatar
Eddie101
Battery test:
Battery voltage before start 12.25v
on starting minimum 9.8v
Maximum 14.59
Alternator test :
Voltage before start 12.10v
on initial startup 11.8v
after a a few seconds 14.46v @ idle
14.5v @ 2000rm
To Car went dead while driving at night.
