Prospeed Cooling fan install wiring help
On the left hand side wiring connector from the PWM, will have Black wire that need to be connected to ground on the chassic, and the red wires that need to be connected to 12v positive source (engine fuse box terminal will work).
If you burnt up the OEM connector on the side of the radiator, then you can buy a replacement connector to keep that OEM connector to keep it all plug and play. GM sells them wired so you can just solder the tail it back to the oem wires with heat shrink wraps, or you can just buy the plug kit with pins instead.
So the fans get wired directly to the battery positive through the PWM, and the PWM is just control the postive wires of the fans to pulse the fans.
So this is the reason that the PWM needs major power on the output side of the PWM since it will be the side that is seeing all the load of the fans, while the input control side of the PWM is pulling minimal power from the ECM and small ground wire to pulse it SSR instead.
https://www.corvetteforum.com/forums...g-diagram.html
Good video is you need it,
And the specs on the PWM since may as let the cat out of the bag at this point.
http://www.crydom.com/cn/products/ca...anel-mount.pdf
Then again, if your battery doesn't have provisions for attaching ring terminals, you may not have another option.
fuse box voltage with fan ramping from OFF to ~22% duty cycle
fuse box voltage with fan at ~33% duty cycle
fuse box voltage with fan switching off (manually)
As you can see, the voltage is very stable at ~ 14.2 V when the fan is off. When the fan is on at some medium duty cycle, your ECM "sees" anywhere from 14.5 V to 12.5 V, depending on when it samples the voltage. This affects all sorts of things, from injector pulse widths to timing to things that are probably buried in the OS invisible to any tuner.
Attaching the fan wires to the battery will produce an inherently more stable waveform because the battery will absorb much of this voltage fluctuation.
The cause of this is that the fans are switched on and off very rapidly in ~ 60 A pulses. Without going too crazy here, this causes big positive and negative voltage spikes every time the fans are pulsed on and off. This can be solved/mitigated by the installation of a large flyback diode at the fan. I brought this issue up to D3PE/Prospeed some time ago, before I bought the fan system, but it was dismissed as "not a problem". It very obviously is. When I have some time to get the car on the lift next week, I'll take some readings of what things look like with the wires on the battery and also how things look with the flyback diode installed. If things look good enough, I'll be reaching out to Prospeed about it, and I may post a tutorial on how to fix this issue if they are not receptive.
I still think this is by far the best cooling option out there for the C6 platform. I'm running mine with a standard size DeWitts radiator and it performs incredibly, except for the electrical issues it causes.
EDIT: looking at the solid-state relay datasheet posted above, on page 2, there is a note saying "Inductive Loads Must be Diode Suppressed". A fan is a large DC motor which is a very large inductive load.
I just recently replaced the battery on my 2017 Yukon Denali (battery went completely flat without a battery tender over a 2 month time period... like 1.6vdc!). GM is using a really nice snap-on positive terminal block on their batteries for those connections that require a direct battery connection. I would also fuse this connection.
Those scope meters are nice!
I wonder if an AGM battery would also exhibit the same capacitive characteristics as a standard lead-acid battery?
Since I had the heatshrink cut off already, I decided to replace them with the beefier/faster diodes I had ordered. I did not notice much difference in the noise.
The scope grabs are taken directly at the fan this time instead of at the fuse box. Tomorrow I will add the PWM signal on a second trace for overlay to see exactly where those spikes are from.
As an EE, I’m honestly a bit confused by why there is still so much noise here. Will do some thinking and consultation.
Diodes installed by ProSpeed
New Schottky diodes installed
Zoomed in view showing pulses resulting from ~125 Hz PWM
Zoomed out view showing lots of noise still present
https://www.maximintegrated.com/en/a...ex.mvp/id/6307
I'm almost wondering if swapping the SSR to a high-side config would change anything on its own.
https://youtu.be/kTZxBqrcBug
Is this
Consider replacement
I mean the same as pro speed using
