Advice needed
Old May 19, 2019 | 10:16 AM
Dirk Miller's Avatar
Dirk Miller
Default Advice needed regarding fuel pump
Ok, finally found the source of my gas stench. After dropping the driver’s fuel tank and not seeing any evidence of a gas leak, I followed the 10 ft fuel line from the firewall to just above the left tank. Now that the tank and mid-pipe exhaust is out, this gave me plenty room to inspect visibly. The former owner had added a SS braided line that we use to clean out the clutch fluid. Without a poly covering, the O.D. of these flex lines have a very rough finish. It was in contact with the fuel line and was rubbing. After pressuring with air, sure enough this showed bubbles. Guess I could have smoke checked this first, but to find this I would still have had to drop the mid pipe to view. So, I’m asking for advice. Now that I spent most of a Saturday taking the gas tank out, should I replace my fuel pump? This is a ’06 ZO6 with 60K miles. No evidence of a crack starting around the 90 degree plastic fitting at the top. Why fix it, if it ain’t broke. Right? Anyone??
Last edited by Dirk Miller; May 19, 2019 at 11:08 AM. Reason: thought it best to clarify title
Old May 20, 2019 | 05:13 PM
Jfryjfry's Avatar
Jfryjfry
If it wasn’t such a pain to get the tank out, I’d say no way. I have 90k on my stock 06 pump.
But with the difficulty involved..... maybe you do.
If you drive it less than 5k/year, maybe I wouldn’t. It should last a long time.
Old May 20, 2019 | 06:31 PM
SixAddict's Avatar
SixAddict
Since you've gone through all that work I would definitely change it out, not worth the few bucks it cost to do so.
I was having my tranny serviced, oil and filter I had the shop replace my shifter cable, not that any thing was wrong with it but I figured they are right there, not worth challenging Murphy on some things.
Good luck.
Old May 20, 2019 | 07:17 PM
Kenny94945's Avatar
Kenny94945
My vote: Change the fuel pump.
Old May 20, 2019 | 07:47 PM
pewter50vette's Avatar
pewter50vette
Another vote for changing fuel pump , had my done under warranty 2009 z06 40,000 plastic fitting on top had a crack in it.
Old May 20, 2019 | 11:39 PM
Dirk Miller
I appreciate the input from you guys.
With this tank sitting on the garage floor, I may put a new one in it.
Ciao!
Old May 22, 2019 | 03:37 PM
theandrewo's Avatar
theandrewo
I vote change/upgrade the pump.
Then tune it for e85 I mean why not?
To Advice needed
