How do i ditch onstar phoning?
Old May 22, 2019 | 05:31 PM
froggy47's Avatar
froggy47
Default How do i ditch onstar phoning?
I paired my android with the bt system. So I push call and it says "using onstar calling" or some chit. How to fix? Thks
Old May 22, 2019 | 07:36 PM
HBsurfer's Avatar
HBsurfer
I am pretty sure there is a dedicated fuse for On Star. Try pulling that fuse out.
Old May 23, 2019 | 12:07 PM
dr_gallup's Avatar
dr_gallup
Probably something else in the setup that needs to be done but pull the Onstar fuse anyway. They track you even if you don't use the service. The Onstar module also contributes to parasitic battery drain.
Old May 23, 2019 | 01:27 PM
froggy47's Avatar
froggy47
Thanks guys, despise the concept/fact of being tracked. ugh
Anyone tell me which fuse, under pass feet I assume.
Old May 24, 2019 | 10:48 AM
dr_gallup's Avatar
dr_gallup
Old May 24, 2019 | 11:35 AM
froggy47's Avatar
froggy47
Originally Posted by dr_gallup
THAT is a beautiful drawing, thanks!
OK to put it on my YT channel?
Old May 24, 2019 | 11:38 AM
dr_gallup's Avatar
dr_gallup
Sure, it's straight out of the owners manual.
Old May 24, 2019 | 11:39 AM
froggy47's Avatar
froggy47
To How do i ditch onstar phoning?
