2006 C6 intermittent starting
Old Jun 9, 2019 | 01:13 PM
vettman6's Avatar
vettman6
Default 2006 C6 intermittent starting
C 6 Stick shift will not start on occasion. Battery is good . Shop has had car for 3 weeks
Old Jun 9, 2019 | 02:40 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Sorry to hear that !!...if a shop can’t figure out a starting issue after 3 weeks I’d take the car elsewhere !!
Old Jun 9, 2019 | 05:08 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
What do you mean by "will not start"? Does the engine crank but not start; does the engine not crank at all? If the latter you might check the clutch pedal interlock switch....clutch needs to be fully depressed for engine to crank on an MN6.
To 2006 C6 intermittent starting
