Clutch problem after ranger refill
Old Jul 4, 2019 | 03:26 PM
rebar's Avatar
rebar
Default Clutch problem after ranger refill
Today I was attempting to replace dirty clutch fluid using the ranger method and after the first refill, my clutch pedal went to the floor and stayed there. My guess is that I somehow got air into the master cylinder and from searching articles found a GM service bulletin that says you have to remove the catalytic converters to access the bleed valve, which I cannot do myself. Am I correct? Is there any other cause for this happening? Is there an easier way of bleeding air out without removing the converters and a tunnel cover? Is it safe to drive 5 miles to the dealer? Thanks, All. (2013 427 vert)
Old Jul 4, 2019 | 06:25 PM
BigBlok502's Avatar
BigBlok502
It sounds like your clutch master cylinder failed, some good info on this thread starting with post #3.
https://www.corvetteforum.com/forums...-cylinder.html
